Page 3 of 3 FirstFirst 123
Results 81 to 120 of 120
  1. #81
    Apr 2013
    779
    good, im wondering how it performs 4s vs. 6s, Not just speed... but performance wise too.
    Might run smoother on 6s if its a real power hungry system?
    To SUMMIT up, its my coolest RC.
  2. #82
    Princeville, Québec
    893
    On 4s at crawling speed, there was absolutely no cogging. And power and torque were at the "rendez-vous" for sure! But i still don't know what gearing i can put on it, i can't find any gearing chart anywhere.
    Summit RX8/1550kv-Slash4x4 MM2/2400kv Twin-V Merv.
  3. #83
    Apr 2013
    779
    No such chart I believe.
    Id get a temp gun and play with different combos till you get the speed/torque/temp you desire.
  4. #84
    Princeville, Québec
    893
    Alright, i'll wait for all my stuff to come in and start experimenting! But i was thinking of outting a 54t spur with the 14t pinion... i Wonder what would happen!? lol
  5. #85
    Princeville, Québec
    893
    I have put my 54t Steel spur and left the 14t pinion... I will run this to see how it goes!
    Envoyé depuis mon Z10 avec Tapatalk
  6. #86
    Apr 2013
    779
    Quote Originally Posted by boilo56 View Post
    You should get a little more speed. But if thats what you are going for, pinions are better to up on the teeth count for speed.
  7. #87
    Princeville, Québec
    893
    I only do this because i don't have other pinion but I have the spur in hand.
  8. #88
    Princeville, Québec
    893
    I just received 2 blue bird BMS-35A for the Beast! It will have 983oz-in of torque to turn those big tires! This will be cool!
  9. #89
    Canmore, AB
    277
    Should be about the equivalent of an 18t pinion (17.6t if you want to get techy)
    Working hard to appear reasonably sane.
  10. #90
    Princeville, Québec
    893
    Quote Originally Posted by Captain Switchblade View Post
    Do you say 18/68?
  11. #91
    Princeville, Québec
    893
    i just put one blue bird BMS-35A in the summit, those little monsters are power hungry! They makes the front leds flashing when i turn the wheels, even if setting the rx8 internal BEC to 7.4v and on 6s! Does someboby knows what sould i do to solve the issue?
  12. #92
    15,140
    A 6.0/7.4 volt, 7 amp BEC should have no problem powering a steering servo for the Summit.
    Alt-241 on the number pad = ±
  13. #93
    Princeville, Québec
    893
    I think it may need more amps, to feed the leds and servo... maybe i can get a 20A BEC from castle?http://www.cafr.ebay.ca/itm/Castle-C...ht_3155wt_1161
  14. #94
    Princeville, Québec
    893
    I went to try the setup on 6s, speed were very fast. I checked the temps and it was 112f on the esc and 152f on motor, geared 14/54. I did only speed run for about 20 min. The only down site is, I killed the spur gear bearing.I think it is good, do you?
  15. #95
    Apr 2013
    779
    Bearing was probably seized already, this run just destroyed it. Ive seen a few of this bearing size seize per-maturley.
    A CC 10A BEC would do fine. I`ll help with wiring if you need any.
  16. #96
    Princeville, Québec
    893
    Thanks NA, i will need help for sure! And beleive me, the combo we have is really insane! I set it up by hotwire, it is a BEAST!
  17. #97
    Victoria B.C Canada
    4,979
    A castle 7 amp will be plenty.
    Feed 7.4v directly from the castle bec to the servo.Tekin at 6v feed the rx and everything else.
    The rx should not be fed 7.4v for any reason it is not rated for that.you may have damaged the rx if its been getting 7.4 v.
    the micro servos will not enjoy 7.4 for long,Again If you are feeding the rx 7.4v That is not good for it.A castle 10 amp will be plenty strong enough and smaller.If I have misunderstood your setup disregard just want to make sure you don't damage anything
    Mountains cant stop me
    they have tried
  18. #98
    Princeville, Québec
    893
    Thanks for the info Jamann, i thought of the 20 amps BEC because i wish to put a BSM-35A for rear steering, and maybe a a snow blower for the winter... or any funny stuff that i can create for the truck!
  19. #99
    Apr 2013
    779
    got my diff gears and axles in for the summit... now to test the tekin system!
  20. #100
    Princeville, Québec
    893
    WOW, those are monsters, i will probably need them too! And i love my tekin system, full of power, very smooth, and fully programable!
  21. #101
    Jun 2013
    10
    Are those axles available to buy?
  22. #102
    Apr 2013
    779
    no, currently testing stage still
    I`ll let you know when!
  23. #103
    Jun 2013
    10
    Thank you.
  24. #104
    Princeville, Québec
    893
    I finally received my 20amps CCBEC to solve my burned servos and flashing light problem, but i don't know how to connect this thing... Can somebody help?
    thanks!
  25. #105
    Apr 2013
    779
    Hope your ready to solder on some battery tabs and have a spare piece of wire.
    Here how I mounted one on the rear body post.
    In the diagram simply ignore the y-harness going into the rx.
  26. #106
    Princeville, Québec
    893
    Thank you NA, it is very appreciated, but mine is a 20 amp, and the wire are not the same... Also i have read somewhere that i cannot plug two bec into the rx... is it true? I also was asking myself if i could only plug the white wires from the servos to the rx, and power the servos directly from the bec?
  27. #107
    Princeville, Québec
    893
    Here is the baby... and here how i thought i saoule connect it... is it ok to do so?
  28. #108
    Victoria B.C Canada
    4,979
    Tekin in my Summit, will it do well?
    Yes bec to power servo only at 7.4v just pulling signal from Rx to servo.The stock bec takes care of the rest.Is your tekin bec set to 6v?
    As I don't think it is from the factory.Need the hot link to set that feature I believe,also for setting your cutoff voltage as factory options are a bit low for my liking.
    Sent using lipo power
    they have tried
  29. #109
    Princeville, Québec
    893
    Yes the bec is set to 6v from the factory. I also have the hotwire. So my connections are ok?
  30. #110
    Victoria B.C Canada
    4,979
    Looks good.
    power bec from bec side.
    Signal split into two
    All looks good to me.
    they have tried
  31. #111
    Jul 2013
    58
    Should not be BEC used to power RX directly? You simply plug it in to free slot in RX and disconnect power supply from ESC. Something like this castle diagram:
    At least I planned to connect it that way.
  32. #112
    Victoria B.C Canada
    4,979
    Quote Originally Posted by Marek_K View Post
    Yes if you want to run everything at 6v.most high torque servos are capable of 7.4v.
    The Rx and traxxas servos are 6v
    they have tried
  33. #113
    woodstock .on.canada
    2,104
    boilo56:i see a posible problem with your setup in post 107(in pic 3)....the way the bec is connected. it will feed off of the one battery rather then both......since the bec can take up to 6s lipo in series. i would sugest hooking it to the tekin esc directly(so it would be in parrellel with the esc)so that both lipo's get discharged evenly
  34. #114
    Victoria B.C Canada
    4,979
    Don't ask me why,I was still going off the EVX issue with bec side.
    Tekin d'uh that should work fine.
    Tekin goes in series before the esc.
    The EVX goes in series internally
    Causing the smoke issue
    they have tried
  35. #115
    Princeville, Québec
    893
    Thanks for the help everyone, i will connect it tonight and post back the results!
  36. #116
    Princeville, Québec
    893
    I finally got everything connected! Here is how it looks!
    The BEC works good, i can't wait to go try it!
  37. #117
    2,104
    a question to you boilo56 :what is the blue box infront of the esc for?
  38. #118
    Princeville, Québec
    893
    It is à light controler box for brakes and turn light.
  39. #119
    156
    SHOW ME THE MONEY!!! Lol, sorry I got excited....show me the video!!! I am so close to buying the same system but I can only dream about it for now.
  40. #120
    Princeville, Québec
    893
    Quote Originally Posted by RcSummitVXL View Post
    You can say that! But it's fun! I will try to put some video together and post it. And if you buy this system, you won't be disapointed!
