    Sep 2010
    8
    Trenchers on 2.5
    Will the 2.5 engine and transmission be strong enough to power these without burning stuff up
    Sep 2010
    8
    They're 2.8 sized tires
    Woodward, OK
    430
    You will have the power, you may just need to drop a a couple of teeth on your clutch bell. What size clutch bell are you running right now? Those tires will be taller so it will be just like gearing up.
    T-maxx 3.3
    Rusty 2.5r
    Summit VXL
    Nitro 4-tec
    Delta, Pa.
    1,829
    You may have problems with drive shafts and idler gears. Really depends on how/where you drive. If you intend on running in tall grass plan on replacing parts mentioned.
    Apr 2013
    Utah
    38
    I am running trenchers on mine but I have a 3.3 in it. I had to upgrade to steel drive shafts. But may not need to with a 2.5. I would also suggest and 18 tooth clutchbell and 72 tooth spur gear. I've had no idler gear trouble yet.
