    Aug 2013
    Spur gear tips!!
    I have a 1/16 summit with a 2s lipo and my spur gear stripped out the other day and I just wanted to know what would have caused this. Could it be hitting the throttle to hard or little debries getting inside. Im new to this and it real fun but I just want to prevent any types of mishaps that a bad spur gear could cause. Thanks
    Alma, MI
    11,957
    There are very few causes to a stripped spur:
    1) Improper mesh
    2) Debris
    3) Too loose of a slipper resulting in a soft center and causing the spur to squish away from the pinion.
    Aug 2013
    Thank you Jimmie Neutron..
    Jun 2013
    148
    @Jimmie Neutron
    What exactly do you mean by that third one? If the slipper is too loose wouldn't the spur & pinion just spin together until the slipper engages, so if the mesh was sent properly why would it wear?
    I mean, you're prob right, I just wonder why that would strip out a spur?
    Alma, MI
    11,957
    A loose slipper can melt the center of the spur, making it soft and unable to withstand the forces of the pinion against it which it will then be forced to unmesh causing it to strip.
    EDIT:
    Here are some pictures of what I am talking about...
    Jun 2013
    148
    Wow! I didn't know a spur gear could melt out like that, I guess there's a tremendous amount of heat buildup on a spinning clutch
