    May 2013
    37
    Tekin RX8 ESC / Redline T8 Brushless Motor combo????
    Any one run this setup?
    Looking for input on it.....
    Lexington, SC
    2,173
    That combo would work well. The esc has tons of adjustment options.
    Jeremy
    May 2013
    37
    Not as fast a the stocker right?
    Lexington, SC
    2,173
    That will depend on the kv of the motor. Maybe try the 2050kv Tekin. Should have good torque and turn more rpm than the stocker.
    Jeremy
    How well would a 1800kv motor do?
    7,171
    Quote Originally Posted by merkyworks View Post
    The 1800kv should be fine. You will pick up a little bit more speed vs the stock motor. Always keep an eye on temps for the first couple of passes and gear accordingly to heat. I've always wanted to run a Tekin so if you pick one up let me know.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    Lexington, SC
    2,173
    Yep you will still get more rpm with the 1800kv motor. Should work well.
    Jeremy
    Michigan
    56
    I am running the tekin rx8 2000kv truggy in my e-revo. it has more than enough torque for an e-revo, for an XO-1 I would consider going to a higher kv. I don't think you will have a problem with a lack of torque. I was considering the 1700kv for more torque but ended up getting the 2000kv because it was available first. I think the 1700KV would have been to much torque for me. I hope this helps, and I am sure what ever you go with you will not be disappointed. If you want some more information on the tekin set up you can pm me.
    E-Revo RX8 2000KV
    Rustler VX4 3900KV
    2WD Slash
