Results 1 to 10 of 10
    New Hampshire
    98
    Jato wont stay running!! Help!?
    my jato will start but stay running unless the easy start is turning the motor over. it was running fine until i put an aftermarket brake kit on but i dont see how this could affect the way the truck runs. i thought it was contaminated fuel but i put fresh fuel in but it still does the same thing. if anyone has any suggestions please let me know. thanks in advance
    Toronto
    168
    How long after the last time you ran it did you run it again? Was it hours, days, months? And did you do any after run?
    Jato 3.3 Pede 2.5R Rusty 3.3
    Gurley, Alabama
    766
    Try a fresh glow plug.
    9,841
    Quote Originally Posted by Mark Ball View Post
    This guy knows what he's talking about.
    New Hampshire
    98
    I changed the brake and then the next day I tried running bits that's when the problem started
    And already changed the glow plug
    T-Maxx 2.5r
    Stampede xl5
    Gurley, Alabama
    766
    The brake won't affect whether the engine runs or not, only whether the truck will roll or not. Try holding the truck off of the ground when starting. If it will run until you sit it on the ground, it's a broken clutch spring.
    New Hampshire
    98
    Thanks I tried the tmaxx glow plug and it it ran just fine thanks for the advance
    T-Maxx 2.5r
    Stampede xl5
    Aug 2013
    17
    You're running rich. Try turning it a half turn lean. And keep going. Until ur at 1 1/2 turns. The. Put it back because I'm wrong and you're running lean. Go up at that point.
    Aug 2013
    36
    What does the whole concept "running rich" mean?
    Jun 2013
    Clanton, AL
    68
    Quote Originally Posted by ApolloDPC3 View Post
    Means you're getting more fuel(nitro/gas/etc) than air in the mixture. Can cause fouled plugs. The same with lean-more air than fuel.
