Results 1 to 19 of 19
    Halifax, Nova Scotia, Canada
    42
    Aftermarket Wheels and Tires
    This truck seems to be designed to fill the gap between a trail truck and a basher.
    Having said that, it seems that a lot of folks are discussing ways to maximize the off-road capabilities of the truck, in exchange for a hit on the bashing side. If I owned this truck, I would definitely be leaning towards increasing the off-road capabilities.
    Iím not going to comment on the electronics. From the trailing point of view, the two most obvious mechanical things to do are:
    1. Lock the diffs Ė Easily done with aftermarket parts or the less-than-elegant-but-free method using a glue gun or silly putty.
    2. Change the tires to devoted off road tires and rims. I.e. beadlocks
    However, looking at this truck, I am wondering whether youíll be able to fit on a set of standard beadlocks. The inner diameter of the Slash rim (i.e. the diameter on the side closest to the chassis) is much larger than the outside one, and this makes it easy for the upright to fit inside the rim. Would a conventional beadlock accommodate this upright? I suppose this is something that will be covered by Jang or whoever reviews it, but to me it is a pretty important question.
    Itís fine that Traxxas chose tires with firmer carcass construction to find a better compromise for bashing, but one would think they would realize a common upgrade would be to add beadlocks.
    Hey, maybe they do fit. But I do think itís an important question for those wanting to make it more of a hard-core off-roader.
    1,556
    There is a video from Jang (Ultimate RC) out there adressing this issue:
    http://www.youtube.com/watch?v=TzTMDVN4cY8
    Apr 2009
    Michigan
    2,297
    Unless your willing to dish out some serious cash you wont be putting non short course beadlocks on the Telluride.
    Oderint Dum Metuant
    Nashville, TN
    1,779
    I think Traxxas may have taken queues off Jang's shapeshifter project 'Chimera B' for this truck.
    A set of proline badlands SC with very soft foams would work well...maybe even no foams at all. Soft compound trencher SC's would work well too.
    Dec 2006
    4,381
    Quote Originally Posted by Jws1982 View Post
    The Chimera-B is a Stampede 4x4 with a Summit body, people have been putting Summit bodies and small wheels on the Slash 4x4 way before Jang did that conversion, so, stop giving credit for something he copied too... Jang is a great guy and has done so many great things, but taking credit for this one is not right... Check the Slash 4x4 MT thread...
    42
    Quote Originally Posted by soundmaster View Post
    Thanks for this link. Definitely addresses what I was wondering. In a nutshell, Jang's solution was to use some Proline rims that had a large negative offset (i.e. these rims moved the tires further away from the chassis). However, I've seen people do this kind of thing, and it can definitely screw up the steering. Too much negative offset increases the load on the steering servo and can lead to sluggish steering. I saw a guy who put some wheels on his Ridgecrest that had way more negative offset than stock. The thing had the turning radius of a battleship with a damaged rudder.
    I admit that this is something that can probably be remedied with a strong-enough steering servo, but it's just something people would have to bear in mind if they wanted to try this modification themselves.
    Jul 2007
    Rc Room
    1,484
    Yep Chimera B was what instantly comes to mind. Yes, others have done it first but Wang has the most visibility.
    42
    A good point, but just bear in mind that two things determine grip with crawler/hardcore-offroad tires: rubber compound and carcass stiffness. Obviously the two are somewhat related, but the fact remains that you can have a tire with very soft rubber that has a very stiff carcass (F1 tire) and one with rubber with the same softness but a very flexible carcass (motorcycle trials tire, for example).
    The stiffness of the carcass would come from the thickness of the sidewalls, the foam used as the insert, etc. The tires on an Axial Honcho or Summit have grippy rubber but the most distinguishing feature is how soft the carcass is.
    There may be SC tires with soft rubber compounds, but the carcass would likely be too stiff for real offroad use. But hey, maybe there is an SC tire with an extra flexible carcass...
    BTW, none of this is meant as a criticism to your response - it's just extra stuff to think about.
    Nashville, TN
    1,779
    Yeah, I wouldn't recommend sc tires for a real offroad RC. But, for the entry-level telluride, they'd be an easy option. It'd be worth trimming the inside of the sidewalls of the carcass out to soften them even more.
    It'd be great if traxxas had a sensored version of the V3500 motor for vehicles just like this. The XL5/Titan will do the job, but the VXL-3s with a sensored brushless 2-pole motor would be a great setup for this truck.
    Jul 2013
    580
    I somewhat agree with you but he is the URC guy, so if another person did this they would receive credit as long as they did more videos about it. The only difference between Jang and other conversions is that he did so many videos on it so therefore he receives most credit. I am not arguing with you so do not take any offense from it. I am just putting my thoughts out there as well. I am sure many others did very many videos on their conversions and what not but like I said Jang is the URC guy so in our world he wins! Again please don't take any offense from my words...
    1,997
    Wealth of info in this video......take from it what you can and make your Telluride "Your ride"!!
    Good Find!
    PM me if ya wanna bash at Greenwood Bashplex!
    13,048
    I thought the chimera "a" (slash 4x4 chassis)had the summit body? The pede chassis is way too short for the summit body.
    Mar 2013
    Lincoln Nebraska
    37
    There is a poster over at rctech.net who switched out the large Traxxas c-hubs with Tamiya parts so he could fit standard 2.2 rims. He has pics posted but no part numbers listed. This might be worth looking into to open up a huge choice of rims.
    http://www.rctech.net/forum/crawler-...uride-4x4.html
    15,555
    That is a very interesting method of going about adding some scale realism. I like it a lot.
    Alt-248 on the number pad = į
    Nottingham, UK
    639
    That's very cool! I'm not 100% sure, but it looks like he used parts from a Tamiya TA01.
    The thing with Tamiya parts is that you buy them in whole trees of moulded parts. If you haven't a TA01 to keep parts as spares, there's a risk you will have to order a couple of trees and end up with a whole bunch of Tamiya parts you have no use for. Also, for those used to super strong Traxxas plastics some of the moulded Tamiya parts will seem incredibly weak and will not stand to much abuse.
    In any case, it is a price worth paying for the scale look A car like the Telluride becomes 1000% cooler if it looks scale.
    PS: Also, the TA01 is ancient, so don't know what part availability is like.
    Dec 2009
    MN
    785
    Found these on the rally forum, they look like a good tire.
    http://traxxas.com/forums/showthread...k-mud-terrains
    Slash 2wd
    Slash 4x4 MT
    P4de Trail
    Jan 2007
    Hibernating in my basement, trying to see just how many RC projects i can work on at one time!!
    1,545
    One thing I did aways back, was use the 17mm adapters and buggy wheels and I cut down a set of crawler tires to fit. Not the best option perhaps, but they worked quite well on my AX-10 rockracer and my BackSlash.
    Sent from my Kindle Fire using Tapatalk 2
    Slash BL-Pede-E 4Tec-FLM EMAXX-Wraith-AX-10-SCX-10
    Aug 2013
    I have a set of rc4wd 1.55 stamped steel white wagon wheels with their rock stompers, those clear, total width is just a hair wider than the stock wheels and I think their baja claws on those wheels would clear. I think their 1.9 stamped steel wheels would probably work also but I don't have a set to try. Like someone else said above, these wheels are expensive compared to the stock plastic ones but then you can have some good crawling/trail tires.
    Jun 2003
    We-Go, Chicago, IL
    2,695
    The HTU I work for has gotten a couple trucks in and we put one on display. It was slow today so I spent some time staring at it and threw together a plan for if I was going to work one over with minimal work.
    So here we go!
    #1. From looking at it, I'd be willing to bet the Proline Renegade beadlocks for their ProTrac Suspension kit would not only fit, but narrow up the track width so it don't look like a S-Blazer with a HUMVEE suspension under it. Since they're heavier too, it would allow for some weight lower in the truck and help the stability and flexibility of the truck.
    #2. Tires I'd probably get the M3 compound Trencher SC with the original style sidewall or the soft compound Traxxas BFG's then modify the foams to have more give to them under load like a 1/1 tire that's been aired down.
    #3. I'd also ditch the stock springs for softer than stock Losi truck springs, should give it a little more flex do it doesn't look like it wants to flop over in an off camber situation, don't think I'd bother with the oil unless it lost a cap.
    #4. Then swap the Titan 12t for a 21t from the Maxx and Revo for more low end torque and gear it down further on top of that. It's a trail rig, it don't need speed, it needs grunt.
    #5. Diffs, I'd go with the heavy oils, maybe Traxxas' 100k in the rear and 500k in the front. Should be able to be done fairly cheap and not cause as many handling issues like you'd see with the spools.
    #6. Body, I'd prefer the red or blue body if I were starting with a new one (the green and orange ones are too gaudy). First thing I would do is pull the stickers off the flares then scuff those and the bumpers that are molded to the body, apply Duplicolor Adhesion Promoter, then Duplicolor Bedliner like I've done with a few of my crawler bodies. Once I got around to getting a clear stock body, I'd probably paint that a darker green color like Model Master's GM Licensed Fathom Green Metallic Lacquer (which is lexan compatible!) then wash-rinse-repeat on the bedlined bumpers and flares.
    That's it, probably spend more on the rolling stock than anything else short of the truck itself, and that would be just as cosmetic as it is functional.
    Last edited by bjoehandley; 09-07-2013 at 02:20 AM. Reason: Forgot about the Diffs.
    Aw, Biscuits!
