Results 1 to 17 of 17
Thread: 48P gears?
    Dec 2006
    4,378
    48P gears?
    I guess because of the Titan right?
    1,496
    seems like it.
    CT
    172
    youll have a better chance of not stripping out the gears because they are "sharper" if you will so theyll have less of a chance of skipping and stripping out
    My stickers totaly effect my aerodynamics
    Apr 2009
    Michigan
    2,297
    48p is more than enough for such a rig. With a good mesh 48p can take quite the beating.
    Oderint Dum Metuant
    N. Idaho... Da Sticks!
    3,223
    48P is what I run on my scaler, it should be plenty tough for what this powerplant can dish out. If it is upgrade to a larger KV motor, then you might want to look at putting 32P on there.
    126
    Quote Originally Posted by lotus2200 View Post
    Actually it's the opposite. The teeth are narrower and thinner therefore making them weaker. Basically all offroad Rc cars/trucks were 32p in the early 90's. they started using the 48p gears in race vehicles because they were quieter and provided a larger range of gearing options allowing the racer the ability to fine time the gearing to each track. They had experimented with 64p gears like what's used in on road cars but those were too fragile.
    294
    its so u can gear it as LOW as possible i read somewhere on the interweb. I don't have a prob with 48pitch gears, i have a bunch and their cheap to get too.
    Greenwood Bashplex
    12,922
    Okay... what exactly is a "high stall gear clutch"???? Could not find any close ups on the product pages...
    The spur is bowl shaped. 48p is not a problem. A flexible bowl shaped spur can be...
    Does the clutch have gears in it?
    Is it a cush type??
    Lost.
    Sit down, buckle up, hold on, pay me...
    Apr 2009
    Michigan
    2,297
    The spurs don't look any different than whats on just about every other Traxxas model.
    As to the "high stall gear clutch" it looks like a fancy slipper clutch.
    Oderint Dum Metuant
    Nov 2008
    Halifax County, Nova Scotia. Ca
    1,131
    Quote Originally Posted by ReaperGN View Post
    Looks like the slipper pad from a mini Revo
    Sent from my highly abused iPhone using Tapatalk
    Always in Trouble for trying to help out.
    Canada
    560
    Well, I think for a brushed setup, it would be just fine for slow driving (like the XL5-Titan combo) but for anything more than that, 32 pitch is better. 48p will strip easier so if you are ever having problems with it, then switch to 32p. I will have a video up soon on my youtube channel (same as my traxxas forum name) which will show everyone how to do it properly. I'll link it here when it'll be up!
    1,542
    I think the main reason for 48 pitch is more tooth (max. 90) whereas the 32 pitch stampede 4x4 max is 54T.
    Apr 2009
    Michigan
    2,297
    Quote Originally Posted by vladsly View Post
    Lots of small gear teeth can do the same job as a few large gear teeth. 32p gears are large and have lots of slop. They also have a much smaller range of gearing options. 48p is is much better for 1/10 rigs and below. With larger ones there is a need for larger gear teeth mostly due to the gear ratio they need to run. Those having trouble with 48p need to practice setting their gear mesh. I have had 48p plastic spurs out last 32p metal gears and steel drive shafts.
    Oderint Dum Metuant
    Greenwood Bashplex
    12,922
    Unfortunately reaper, the bowl shaped spur will flex under higher loads. Its not the gear pitch, its the design of the gear that could cause it to fail, even with perfect mesh. I really wish that a disk shaped spur was provided. If going to higher power motor systems, a normal 4x4 slipper will prob be needed, but then the super low gearing wont be...
    This new center system is designed for lower power systems...
    Apr 2009
    Michigan
    2,297
    Never had a issue with them. Even on 4s with a 2400. This is also the first time I have seen someone say it flex's. Since the Traxxas 2wd models run the same spur with 2.8 tires it wont be a problem unless the person using it cant set the mesh right.
    Oderint Dum Metuant
    Greenwood Bashplex
    12,922
    I give up.
    Aug 2013
    Connecticut
    44
    48 P gears are less likely to skip teeth, but they also have their dis advantages, like they are easier to strip out because the teeth are thinner
