Results 1 to 7 of 7
    171
    Can you link a non traxxas rx to a traxxas tx?
    I started losing range on my mini summit and found out I pinched the rx antenna wire under the shock mount. A result of working in bad lighting.
    1,595
    No i don't think so.
    Aug 2013
    Melbourne, Australia
    15
    no, it cant be done
    15,707
    If the radio is AM and the same frequency (has the same crystals), then yes you can use different manufacturer's Tx and Rx. If the radio is 2.4GHz, then there is little to no chance the Tx and Rx will be compatible.
    Alt-248 on the number pad =
    171
    Thanks soundmaster, raven and ksb for replying! I will buy a new rx.
    1,595
    Quote Originally Posted by RcSummitVXL View Post
    Why don't you just get a new receiver?
    Have you got the TQI radio then the older 2218x will also work?
    If you are skilled you could also just buy a 2.4 ghz wire and resolder it to the receiver board. I did this once. It's pretty tricky but worked for me
    Alma, MI
    12,283
    Ummm... that is what he said.
    "I will buy a new Rx"
    Rx = receiver.
