Page 1 of 3 123 LastLast
Results 1 to 40 of 93
Thread: CSTBOY's XO1
    Oct 2010
    HOUSTON, TX
    132
    CSTBOY's XO1
    Well today I start on this xo1 . Don't expect a bunch of mods and nice paint. Just doing the best I can with what little know how I have. So lets see what happens......
    Tighten up the rear with some revo springs black
    Installed servo
    Tighten up the front , and added 3.5oz of weight.
    That's all for now.
    And removed rpm sensor.
    Lexington, SC
    2,109
    Looking good so far!
    1,209
    hey I see everyones installing the savox servo...what's wrong with the 2075 servo? is it trash or does "upgrade means better" not trying to be rude, im just wondering because that's all ive been seeing and soon i'll have an XO-1. Is there something I don't kno about the 2075?
    Garden Grove CA
    180
    Savox is ok, they're strong fast and inexpensive but require lots of power so BEC might be needed or you'll brown out. 2075 is a bit slow so response isn't that great, plus the gears they're plastic so they'll get worn out and centering will be off eventually.
    IMO you'd want something fast with a good amount of torque to handle the load of going high speed. Use the inner hole on the servo arm (closest to servo center) to reduce overall steering throw. Having the car able to do a hairpin turn on low speed is good, but not something you'd want going over 100mph.
    Oct 2010
    HOUSTON, TX
    132
    Next on the list, Aluminum drag link.
    Oct 2010
    HOUSTON, TX
    132
    Lexington, SC
    2,109
    You must be one of the guys I was bidding against lol.
    Oct 2010
    HOUSTON, TX
    132
    Yea, but I lost. Go thing I got in contact with him, he stays a few miles down the road. He plans to make more and become a member of the forum.
    Oct 2010
    HOUSTON, TX
    132
    I see good things down the road from him.
    Oct 2010
    HOUSTON, TX
    132
    Perfect fit......
    Nov 2008
    St. Louis, MO
    444
    I need one of those!
    RSR
    KPGC treasurer (& BuRPS addict)
    Lexington, SC
    2,109
    Use that in combination with a slash 4x4 aluminum steering set and that should eliminate a lot of slop.
    Garden Grove CA
    180
    Not possible bro
    23
    I could certainly use one of those drag links.
    Oct 2010
    HOUSTON, TX
    132
    i will get the maker of the drag link info for those who want it.
    Lexington, SC
    2,109
    Quote Originally Posted by FartOfDoom View Post
    Not possible bro
    How's that?
    7,096
    Hmmm....I'd be interested in one too.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
    Garden Grove CA
    180
    Have you tried it? You should take a look at the configuration of the slash vs xo-1. Yes even though they use the same exact parts minus the center link, the aluminum bellcrank system has the servo saver spring setup on the LEFT side. Not possible to swap it over to the Right configuration like the XO-1.
    The ONLY setup that's somewhat close to the XO-1 system is the slash 2wd Pro-line steering kit. Difference is the crank arms, they're set at 90 degrees vs XO-1 at ??? (not sure cause I'm currently not home)
    Jul 2013
    NW Houston TX
    5
    There is one on ebay....
    http://www.ebay.com/itm/261255382964
    Lexington, SC
    2,109
    I didn't even think about that. Ugh!
    Oct 2010
    HOUSTON, TX
    132
    I decided to begin with a differ platform this time around, So the mmm 2200 on 3s it is. I know I will have to watch temps. You guys know of anyone out there making light weight pinions? Does anyone with experience with this combo on the xo1 have a good start gear ratio? Thanks
    Garden Grove CA
    180
    Yes sir, pm'd
    May 2009
    Edmonton, Alberta
    3,546
    I'm running a 2200kv with the Mamba Extreme (XO-1 OEM).
    Plan is 2x2s lipo. I have 16/46 (stock spur anyways, looks like it says 46 on it) in there now to start.
    Don't know if that's anywhere close to where i need to be and i have no idea where this "should" be for top speed.
    Lexington, SC
    2,109
    I ran the MMM esc and a 2250kv motor in my 2wd with 34/36 gearing and have run a best of 85.2 on 4s. With 3s make sure you watch your battery temps as well. Depending on your gearing it could really put a strain on a single 3s.
    Oct 2010
    HOUSTON, TX
    132
    Sorry, I meant 6s
    Lexington, SC
    2,109
    I would start with 34/46 gearing until you get a feel for it. That's plenty to run 100 mph.
    Oct 2010
    HOUSTON, TX
    132
    Anyone know if there is a weight difference between the xo1 stock wheel and the dish wheel?
    Sent from my SPH-L710 using Tapatalk 4 Beta
    Lexington, SC
    2,109
    My stock wheels and tires are used and my dishes are new, but here is the comparison.
    Stock rear: 5.5oz
    Stock front: 4.9oz
    Dish rear: 6.1oz
    Dish front: 5.3oz
    Oct 2010
    HOUSTON, TX
    132
    Wow, I didn't expect that. Thanks for that info ponie. I make look into those sweep wheels I keep hearing about.
    San Jose, Costa Rica
    704
    Looking nice
    Sl4sh MM2
    T-Maxx 3.3
    Summit 1/10
    Sl2sh VXL
    Lexington, SC
    2,109
    CST, just keep in mind my stockers are far from new. But I was a little surprised they weren't heavier than the dishes.
    Lexington, SC
    2,109
    I took a look at this again and since the two cars use the same part number, then you can configure it to fit either vehicle. So, I think the Slash 4x4 aluminum steering set will fit the XO-1.
  33. #33
    Oct 2010
    HOUSTON, TX
    132
    I will look into that when I get in. Ponie have u done anything with ur diff oil weight front and rear. I was thinking of trying 100k on both.
  34. #34
    Lexington, SC
    2,109
    I have not changed the diff oil. It's stock. Imo I don't think it really helps.
  35. #35
    Oct 2010
    HOUSTON, TX
    132
    a set back today. the mamba esc i purchase doesnt work. this is what i get for tryin to save cost on my budget build, and not buying new as i always do. the rx powers up and servo moves. but esc doesnt do anything. green light shows when connected to castle link. any ideas other then send to castle and wait. ?????
  36. #36
    Lexington, SC
    2,109
    So nothing when powered up? Could be the switch. I started having trouble with the switch on mine. Bypass the switch before sending it in.
  37. #37
    7,096
    Is it solid or flashing green? You might want to re-callibrate your Tx/Rx. See if that works.
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
  38. #38
    Oct 2010
    HOUSTON, TX
    132
    The only thing I get when switched on is power to rx and servo. I get green only when plug into caslte link. I guess that shows communication between the two. Pc/esc
  39. #39
    7,096
    Might try and cut the switch to the ESC and wire the 2 wires together (as ponie said). The switch hours or in them, I've had to do it a couple of times.
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 4 Beta
    Weak Revenge
    Strong Forgive
    Intelligent Ignore
  40. #40
    Oct 2010
    HOUSTON, TX
    132
    i will try that when i get in. thanks
