Results 1 to 13 of 13
    Jun 2013
    44
    e revo steel driveshaft junk
    Bought Steel driveshafts (5451r) for my e revo. They are junk so far.. They non stop keep sliding out of the socket... have not got the chance to drive it?! Anybody have ANY idea what is wrong!??! my wheel is REALLY wobbly too..
    Jun 2013
    44
    And to top er all off, my wheels go against each other, AND my steering isnt working properly anymore!!! http://www.youtube.com/watch?v=401lj1SNzhM
    Aug 2012
    78
    One of your differentials is up side down.
    Jun 2013
    44
    diffs only fit in one way though do they not?
    15,445
    Nope, they fit upside down too. That is the reason the differential cases read "↑ UP REVO."
    Is there someone you can enlist to help with the re-build?
    Alt-248 on the number pad =
    Aug 2012
    78
    Edit: ksb51rl beat me to it.
    Jun 2013
    44
    well dont i feel a bit dumb lol, thanks i know it says this side up or whatever, just must not have been paying attention! thanks guys
    Jun 2013
    44
    Any idea what the wobble would be?
    15,445
    Quote Originally Posted by nefoley View Post
    Switch tires. If the same tire on a different axle wobbles but a tire on the original axle doesn't, then you likely have water or sand/debris in your tire. Do your tires – not wheels – I have holes in them to let air and water escape? Do you run through water at all?
    Sent from my iPhone using Tapatalk 2
    Jun 2013
    44
    no, i do not run through water very often, say the car is shut off, and i grab the tire and wiggle it the front right and back left move WAY to much compared too the other two, have tried switching tires...
    Jun 2013
    44
    the driveshafts just keep falling out of socket without my running the truck, just moving it around... Worried about whats gonna happen when i run it....
    Oct 2008
    Soldotna, Alaska
    730
    What rockers are you running?
    You cannot run LT rockers with the CVDs.
    You should order the extended drive cups for them, they help A LOT.
    Also, do not run your push rods in the outermost holes, especially if you have RPM a arms (no idea if you do or not). Middle holes are perfectly fine.
    I have RPM arms, which flex a lot which makes it easier for them to fall out. But I run my pushrods in the middle holes and the extended drive cups, and with that setup I have NEVER had one fall out. And I bash the truck extremely hard.
    Using while stupid may cause serious injury.
    Jun 2013
    44
    Thanks. Guys got er figured out last night turns out I f was running ltrockers but now my wheel is really wobbly
