    Jul 2012
    60
    Upgrades to E-Revo
    I am in the middle of taking out my rear. I plan on replacing the suspension arms with RPM and etc. But the thing that I am not for sure to do is the Differential Components.
    This is were I am stuck at...
    should I put in part # 7014ifferential kit, center or should I keep 7078: Differential assembly.
    Any suggestions for me.
    Thank you
    Alma, Michigan
    12,290
    7014 is the center diff for the transmission.
    7078 is the complete diff assembly for the bulkheads/axles.
    You are comparing apples and oranges...
    Usually all that wears out is 7079, but if you are getting excessive leaking 7078 will help with that.
    Jul 2012
    60
    Thank you Jimmie. Yes, I am comparing them.
    So, TRA 7014 will replace the part numbers 7092 and 7093. Would that be a good idea to replace it?
    Once again thanks.
