    Jul 2013
    newbie just boughten rally
    so when i place the rally on the ground and push it it makes a wierd sound is this normal??? please help
    Sep 2010
    the giant boot. Anybody?
    2,727
    It will sound like it is clunking. This is normal due to the motor and the 4wd system. The center shaft is built in to slide for and aft to keep from binding and breaking. post a vid so we can be sure of the sound. Welcome to the forum and future addiction.
    Jul 2013
    63
    Quote Originally Posted by jeff fa fa View Post
    "boughten"?
    Jul 2013
    thanks i eat dirt i will post a video asap
    im not very good at spelling things my question is why are you questioning my spelling when this is and rc car forum not an english class forum
    El Cajon Ca
    1,804
    Now, now, lets all be nice!!! Welcome to our and now your world.....
    For the most part just as I EAT DIRT mentioned, it is a character of the motor and 4wd system.
    My Slash 4x4 does the same.
    "enjoy your ride"
    Dennis
    South of St Louis
    5,994
    Welcome to the forum jeff. Why are you pushing your truck anyway? This sounds normal on 2wd and 4wd TRX vehicles.
    Sep 2010
    492
    Try this:
    Move the motor away from the spur gear so they are no longer connected. Without the pinion / spur touching the truck should roll with a minimum of noise. You'll get some noise from the center driveshaft but it shouldn't be too much. Primary concern is if it rolls freely. If there is any binding you'll need to tear further into it to figure out why.
    Once you verify there is little or no rolling resistance just reset your gear mesh so there is just a tad of backlash between the gears and you should be good to go. If it's making noise after that you could try a new pinion and spur gear, sometimes the teeth get worn and will make noise, but if the truck is new that shouldn't be a problem.
    Indiana
    733
    Just a tip when meshing the gears back together I like to use a strip of paper and push them together tighten them down and rotate the spur till it spits the paper out should look like a crinkle cut french fry lol
    Let's Go Steelers!!!... KCCO
    Jul 2009
    Ontario, Canada
    11,145
    The drivetrain on these cars has alot of play... when you roll it the magnets in the motor create resistance and it ends up making a chattering sound. Its not a problem. Grinding sound, yes... chattering sound, no.
    Pede, Summit,
    ERBE, Rally,
    Motley Crew, 1SQ
