Results 1 to 20 of 20
    Jul 2013
    Killadelphia, PA
    67
    Po' Mans Lowering
    Well, I used the old zip tie method and it's actually not bad...for free you can't beat it....speeds seem increased and overall handling and performance have also improved... And it doesn't look low budget at all...to the untrained eye it looks professional enough...not bad for a quick 5 min free tweak
    _ _
    Law #29: Plan all the way to the end.
    Marshal Dadx2mj's Avatar
    Aug 2007
    So Cal
    21,274
    You can do the fuel tubing method for ~$5. IMO a much better solution to lowering any RC and there is no visible evidence of your handy work.
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
    Jun 2013
    So-Cal
    242
    That's how mine is done.
    Jul 2013
    Killadelphia, PA
    67
    I was lookin at that method...might do it soon...that's kind of why I used the zip ties...I had them..I don't have the fuel tube at the moment...I just did it to see if I liked it and how it would perform...not a perm suspension job but a good quik fix..plus if I wanna run off road I can just snip em and I'm ridin high again
    _ _
    Jul 2013
    Killadelphia, PA
    67
    Zip tie method....
    _ _
    Feb 2013
    Sicily
    43
    post a photo of where the zip ties are at please, this i gotta see
    Jul 2013
    Killadelphia, PA
    67
    lol...I will later
    _ _
    Jul 2013
    Killadelphia, PA
    67
    They're basically looped through the A-arms and then around the top of the shock towers...it's not as clean as fuel tube but it also doesn't look completely jacked either....I'll show u later
    _ _
    Jul 2013
    Killadelphia, PA
    67
    _ _
    Jul 2013
    Killadelphia, PA
    67
    _ _
    Jul 2013
    Killadelphia, PA
    67
    Obviously I could clean it up a little better and snip some of the ends down but like I said I literally thought of doing it and did it in less than five mins and then took it out to run it...again not a perm fix...not as clean and professional looking as fuel tube...but not bad either...good enuff for me at the moment
    _ _
    Feb 2013
    Sicily
    43
    it doesnt look that bad bro , awesome
    Jun 2013
    So-Cal
    242
    After seeing how you did the zip ties, I just may have to remove the fuel tubing and use zip ties instead. Far easier than changing shocks for different road conditions which is far easier than removing and replacing fuel tubes.
    Great idea....should work plenty good enough.
    Jul 2013
    Killadelphia, PA
    67
    Yeah that's a major positive to the method...It's pretty much an adjustable on-the-fly suspension system..I can go from slammed to the ground, to sitting tall for off-road, and back to lowered again, Just by snipping the zip ties and re-installing them when needed. And when you are putting them back on you can pretty much decide how low you want to sit..depending on your driving conditions...plus a few zip ties in your pocket really doesn't take up much space...it works perfectly for me
    _ _
    pennsylvania
    348
    How do you do it with fuel tubing?
    Jun 2013
    Delaware
    452
    Quote Originally Posted by rcguy1324 View Post
    disassemble the shock, put fuel tubing on the shaft, put the shaft back in the body so the fuel tubing is now inside the shock body. It just limits how far the shaft can drop inside the body.
    pennsylvania
    348
    Oh, thanks for the explanation.
    Jun 2010
    46
    How does that work with the mamba on the launch? Does the front end still lift?
    Sent from my Droid DNA using tapatalk 2
    Jul 2013
    Killadelphia, PA
    67
    It depends on what battery I use...on NiMH it doesn't really raise up too much but on 2s it will pop wheelies on command, even when I'm already at a pretty decent speed. (Note: The results I've experienced were geared at 29/76)...if you ease into the throttle its not so bad but when u punch it it gets a little wild...the top speeds are pretty fast...idk for sure as I haven't put a gps In it yet but its pretty sick....I will say tho that you need to be on a pretty flat surface....even a smooth looking street may have some type of divot in it and It will elevate the car of the ground andbecause the wheels are spinning so fast when they touch the ground again its not hard to lose control via fishtail....I do have my car basically slammed to the ground tho...perhaps a tad too low...strictly for smooth even street...even on sidewalks it scrapes a little...since I've put the castle setup in and geared it high, the tread on my tires has depleted at an alarming rate...(stock Alias)..I know that doesn't help traction at all so once I get new tires ill see how it acts....I love it tho...and. like I said if I want to adjust my ride height all I gotta do is snip the ties and I'm back to stock height...quik n easy
    _ _
    South of St Louis
    5,994
    That's a sweet mod. That ranks right up there with the 2-cent washer mod for the differential.
