Results 1 to 12 of 12
    Apr 2013
    360
    is there a way to adjust the brakes?
    My mini summit and mini revo both dont stop quick enough for me...Are the brakes adjustable?
    Mar 2001
    Spring valley mn
    1,135
    Nope, one of the big down falls on the VXL 3m.
    My tranny case is stock :D
    Apr 2013
    360
    dang... its like there is almost no braking at all
    Alma, MI
    11,950
    I found the same thing... but:
    When I changed my ESC, I had good brakes.
    - Everything else was stock.
    When I changed my controller, I had good brakes.
    My conclusion was that it has something to do with the combination of the stock controller and ESC.
    Mar 2001
    Spring valley mn
    1,135
    I know, that was one of the things that made me decide to upgrade to a Mamba Max.
    Vic. Australia
    121
    tighten the slipper clutch a little bit?
    1/16 EREVO, 1/10 SUMMIT
    Paved Paradise Florida
    121
    Thumbs up
    do you have the TQi? if so, brakes are adjustable.
    MERV - 3S 23/50
    Apr 2013
    360
    Quote Originally Posted by iDrive View Post
    Not on this car no...
    Nov 2011
    277
    That makes sense.
    I am assuming it was a programmable ESC?
    As for tx/rx swapping out, the stock system does all its "programming" through the TX/rx, so swapping that out should change things a bit.
    Birmingham, AL
    443
    If you change your ESC to something like the Mamba Max Pro, you'll have enough braking power to do front flips.
    Mar 2001
    Spring valley mn
    1,135
    Quote Originally Posted by fastmachine View Post
    Even with the brake power turned way down! I had my brake power at 50% and in a panic brake situation I found it was to much, so I turned it down to 25% and again in a panic I was cart wheeling across the yard. Maybe 12% will be safe.
    141
    True, when I changed my ESC to sidewinder sv2, I had good brakes, anything else was stock.
