Results 1 to 10 of 10
    Jun 2003
    7
    help with driveshafts
    I got the steel driveshafts but they keep falling out of the cradle anyone else having this problem?
    Long Beach, California
    6,243
    down below has the same problem, check it out.
    http://traxxas.com/forums/showthread...xas-Steel-Ones.
    | Rally GT8 Powered By CC |
    Jun 2013
    265
    Just buy the extended drive cups and screw your pillow balls in a little more (no thread visible).
    Bash it like someone else has to fix it!
    Jun 2003
    7
    i tried the extended drive cups now it binds.
    6,243
    you got any pics for us to see?
    Jun 2003
    7
    I figured it out. I had my tie rod on the inside hole so I moved it to the middle, should help it not fall out
    Apr 2008
    Indiana
    246
    Are the extended cups just for the rear or can they be used for the fronts too?
    ERBE/JATO 3.3
    Jun 2003
    7
    They can be used for both but they bind because there to long
    Jun 2013
    Carson City, NV
    45
    I've Had The Same Problem. You Need Traxxas Part #5153R. This Will Fix The Issue. With The Long Travel Rockers On Though The Shaft Will Rub On The Cups When The Wheels Are Off The Ground. Or If The Links Are In The Inner Hole. Not To Much Of An Issue, But it does cause the car to nose dive slightly when jumping. I put mine in the middle hole like the stock setup and put back on the P2 rockers. Since then not one has fallen out. The drive line occasionally might bend slightly but they bend back easily. Hope this helps and best of luck.
    Jun 2013
    265
    Quote Originally Posted by DoubleEagle View Post
    I run extended drive cups front and rear, p2 rockers, pushrods in middle hole and my driveshafts do not bind or pop out!!
