Results 1 to 11 of 11
Thread: Slipper Clutch
    Jul 2013
    15
    Slipper Clutch
    Can someone please post a pic of this? I don't know what to adjust. Thanks in advance.
    1,161
    Download the manual. It gives you a good pic. Also check out utube lots of vids.
    Jul 2013
    15
    Oh, good call. I always forget everything is on YouTube. Thanks!
    1,161
    The easy things are also the easiest to forget. Hehe I do it all the time
    Feb 2013
    PARKER COLO
    780
    Look at the transmission and on the motor side is a small nut. On the other side of the transmission is a small pin that sticks out of the transmission with a hole in it. Put a small screw driver or hex driver in the hole to keep the tranny from turning and use the wrench supplied with the truck to tighten the nut. I would tighten the nut fully and then back off 1/4 turn. Try that and if its still to tight or loose then adjust the nut (clutch) in 1/8 turns until you get it where you want. You don't have to disassemble anything to do this. You can also use the search feature above, type in slippery clutch and there are many threads about what to do.
    Jun 2013
    265
    Slippery clutch - gets me every time
    Bash it like someone else has to fix it!
    Sep 2009
    Victoria B.C Canada
    5,078
    Tighten until the coils of the spring just touch.then back off as stated.
    Over tightening of the slipper nut can bend the arms that hold the pads.
    Uneven pressure will wear the bearing and cause some other issues
    Sent using lipo power
    Mountains cant stop me
    they have tried
    Jul 2013
    15
    How do I know if it adjusted properly when driving it?
    Apr 2013
    Ontario, Canada
    778
    Does it slip under heavy acceleration?
    Oct 2012
    Canmore, AB
    327
    Bingo! Couldn't figure out why my spur was a bit wobbly....
    Thanks for that tidbit jamann.
    Working hard to appear reasonably sane.
    Feb 2013
    PARKER COLO
    780
    Quote Originally Posted by Fatoolio View Post
    If you can do wheelies or actually flip the Summit your probably to tight. If you accelerate and the Summit takes a while to get to speed your probably to loose. JAMANN is right you want to tighten the nut until the coils touch. Then adjust. Pretty much with everything you do on the Summit you really dont want to muscle tight anything. You'll either strip things out or break parts. When things are tight your good. Play with the adjustments in the clutch, its fast and easy to do. You might even want to back it out 1/2 or turn or more just to see how the Summit reacts to a loose clutch and adjust from there.
