    Jan 2010
    mid michigan
    490
    tekno axle carriers
    any one use the tekno axle carriers with the traxxas cvds do do they used the stock inner bearing
    men drive nitro
    Jan 2010
    mid michigan
    490
    could i just put a 6x16x5 bearing in the outer and be good to go
    men drive nitro
    Jun 2009
    Cocoa Florida
    3,808
    Quote Originally Posted by Ztater View Post
    Yup, it uses the stock sized inner bearing with a 16mm OD outer bearing.
    Look out for the tree/crunch!
    LiPo? Naw NITRO!!
    Jan 2008
    Sugar Hill Ga.
    8,337
    Yep, the outer bearing would need to be 6x16x5mm and you then need to use 6mm ID shims between the outer carrier bearing and the wheel hex to remove the in/out play of the cvd.
    Jan 2010
    mid michigan
    490
    yea ive got the shims but i finnally killed my stockers ok well just cracked but want a strong solid carrier to replace them and i eat throught the 6x12x4 outers like crazy and figured a 16mm bearing sholdent lockup very easy like the stockers
    men drive nitro
    Jan 2010
    mid michigan
    490
    has any one ever used the strc carriers what would be the pros and cons between the strc and tekno
    men drive nitro
    Georgia
    162
    I run the Tekno on my Emaxx and they have been great. Watch this video and tell me if you think they will hold up. This is me crashing my truck and it cartwheeling a few times. I have had them on for over a year now and all I do is bash the truck and not a single issue
    http://www.youtube.com/watch?v=ArNVWm-DBSY
    Watch this video and fast forward to 1:15 where I catch a tree with the front passenger side tire. Any other knuckle and it would have pulled the pillow ball out of the knuckle.
    http://www.youtube.com/watch?v=drqm4rrgRBQ
    Forgot to mention, when I first built this truck I had RPM knuckles. I pulled a pillow ball out of one of them the very first run.
