Results 1 to 2 of 2
    Jan 2010
    mid michigan
    526
    1/8 diff gearing
    i have the old nonsealed flm diffs and want to upgrde to a sealed diff and was thinking flm ultimate diffs how much will this change my gearing i have a oomp 2nd gear locker and a 40/17 gearing on the clutch bell and like the gearing l run a losi 4 shoe clutch and use revo m1.0 spur so the most i could go is 36/18 will that be enoufgh to offset the 1/8 diffs
    men drive nitro
    Jun 2009
    Cocoa Florida
    3,918
    Stock gear ratio is 2.85, ofna 6&8 spyder,Losi LST2,UE diff ratio 3.31.
    The higher the number the lower the ratio, so you will have to make it up by changing the spur/CB ratio.
    40/17 with stock 2.85 gears, when you change to a 3.31 gear these spur C/B will be the same,
    40/20
    38/18
    36/18
    You can play with the roll out calculator here, just put in the correct info.
    http://www.scriptasylum.com/rc_speed/rollout_ratio.html
    Look out for the tree/crunch!
    LiPo? Naw NITRO!!
