Results 1 to 19 of 19
    Aug 2008
    St Amable , QC , Canada
    238
    Spartan top section come off !!
    What kind of glue i can take to rejoin the top sectin to bottom section (hull) , because mine begin to separate ??
    Here some pics of what i mean !
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    May 2013
    Sarasota
    76
    Watch this....
    Aug 2008
    238
    Quote Originally Posted by Yipscidleedoo View Post
    thank's , i will take a look at it , hope i can find it in canada !!
    El Cajon Ca
    1,804
    You can use any good quality ABS cement for the Spartan hull. Just not a PVC cement....
    "enjoy your ride"
    Dennis
    Jun 2011
    374
    I use a two part Loctite plastic epoxy that comes in a side by side syringe that is available at most hardware stores. Use masking tape on the side of the hull to prevent glue from getting on the side where you do not want it. This epoxy sets up in 5 min.
    Aug 2008
    238
    Like the glue we can use to fix abs pipe!?
    Quote Originally Posted by SJS View Post
    Oh , i got a lepage speed set epoxy in syringe glue set in 5 mins !! So you thinks it can do the job ?
    El Cajon Ca
    1,804
    Quote Originally Posted by Banzee View Post
    You bet... the Hull is made out of ABS and ABS pipe cement will bond the hull and deck!
    "enjoy your ride"
    Dennis
    Aug 2008
    238
    That's good , i good abs cemen in stock ! Hummm not sure , i got yellow one , i think i will try to find a clear one !
    May 2013
    Sarasota
    76
    Does the abs glue just bond, or does it fuse the plastics together? The plastruct bondene chemically reacts to chemically melt the plastics together. Just wondering.
    Watch this....
    Aug 2008
    238
    Good question !
    El Cajon Ca
    1,804
    It fuses the plastics together.
    Most abs cement/glue is black so use caution when applying.
    You can also use acetone or MEK, but be cautious as these are extremely flammable.
    "enjoy your ride"
    Dennis
    Aug 2008
    238
    whitch one is better for in water use , like we do ?
    El Cajon Ca
    1,804
    They are all good for use in water. MEK and Acetone are clear but quite costly. ABS cement is black so you just may want to mask off any exposed area.
    "enjoy your ride"
    Dennis
    Aug 2008
    238
    Thank's !
    Here what i got in stock for now
    El Cajon Ca
    1,804
    That will work just fine.
    Just mask off the area where you don't want the cement to discolor the hull or top section.
    "enjoy your ride"
    Dennis
    Aug 2008
    238
    Ok thank's , i will try it and give you some feedback !
    Aug 2008
    238
    Just tryied the glue i post a pics earlier !! here some pics ! Yes i know , i did not do a clean job , i just want to be sure that water won't come from that point !
    when the boat will pass at 35 mph + , i don't think it will be noticable !! Lolll
    El Cajon Ca
    1,804
    It may not be real pretty but as long as the two parts stay attached and the water stays out, that's what is important!
    Good job and no one will notice as you go by.....
    "enjoy your ride"
    Dennis
    Aug 2008
    238
    Loll ! You are right , if i don't talk about it , they will see ..... nothing !!!
