Results 1 to 15 of 15
    Jun 2013
    10
    Turning to left on brakes
    Hello,
    I have problem with my erbe.
    I niticed problem on last race. When I brake very hard, my erbe wants turn to the left. Always to the left.
    I tested it on asphalt too. It is tha same. When front of the car is fully down (not skid touching ground), erbe is turning to the left.
    Trims are good, servo don't do this problem.
    Where I have to begin finding problem?
    Wrong geometry (camber) or wrong lenght of dampers...?
    Thank you for your advice.
    kansas
    7,859
    have a wheel bearing going out.....??
    El Cajon Ca
    1,804
    If you just let off the throttle and coast, does it stay straight or other?
    "enjoy your ride"
    Dennis
    Jun 2013
    10
    Bearing are good.
    Without throttle it stay straight. It turns only on hard brakes.
    Norfolk, va
    1,167
    Front diff may be failing.
    ERBE, ERBE, Summit, Slash 4X4, Bandit,
    Jun 2013
    10
    May be. I will try. I have diff to change. But "on table" it looks like good.
    And what about different lenght of rear ampers or pushrods and different droop on rear arms?
    Jun 2009
    W Monroe, Louisiana
    1,995
    Yep it could be the diff, wheel hex rounded out, broken axle pins, etc.
    Caster, Camber, Shock Preload, shouldn't make the truck pull when braking.
    Jun 2013
    10
    I tryed simple think. On the ground I lifter rear of erbe in the center and LR wheel stayed on the ground little bit longer. So I put RR pushrod to the inner hole on arm......and erbe become turning to the right. I revised dampers and pushrods a RR pushrod is little shorter then LR. So i will refill dampers and set pushrods right and hope, it will be good.
    Jun 2009
    W Monroe, Louisiana
    1,995
    Good point, it never hurts to get the truck back to stock specifications. Replace any of those plastic rod ends that seem worn or stripped.
    El Cajon Ca
    1,804
    Quote Originally Posted by mef_cz View Post
    It has been a few days since making changes..... Did your changes with the pushrods etc make it stop straight again?
    "enjoy your ride"
    Dennis
    Jun 2009
    W Monroe, Louisiana
    1,995
    Bump. I'm curious too. Did you get it sorted out mef?
    El Cajon Ca
    1,804
    Maybe the truck turned left and never came back!!!!
    "enjoy your ride"
    Dennis
    Oct 2010
    NJ
    777
    Quote Originally Posted by orca44 View Post
    haha!
    Jun 2013
    10
    I am sorry, I was busy at work.
    refilled dampers and revised long of pushrods solved my problem.
    But erbe was nervous and still turned, but not to only one side.
    So I changed front spring for harder to not allow front of truck drop down so much on brakes and now, erbe has more weight on rear side and it looks like my problem is solved.
    El Cajon Ca
    1,804
    Good to hear that you got the problem fixed.... I was loosing sleep not knowing LOL!
    Just some fine chassis adjustments and no new parts, good for you....
    "enjoy your ride"
    Dennis
