Results 1 to 20 of 20
    Russia Samara
    75
    5352X friction pads collapsed in more very small piece.
    Hello all !!
    The my slayer in broken status now because TRA5352X collapsed .
    I can make friction pads from aluminum but i want know efforts for this unit.
    What is the limit force should provide a module built on TRA5352 (XR)?
    Best regards!!
    Gurley, Alabama
    750
    I make my slipper pads out of a radiator hose, it works better than any of the high performance aftermarket pads I tried.
    Dec 2008
    Gettin' Lucky In KY
    3,861
    I run the aluminum pads myself with nothing but success. They hold up much better than the fiber pads. Just make sure to scuff them in before installing them or they'll slip too much and get very hot.
    Russia Samara
    75
    Quote Originally Posted by Mark Ball View Post
    radiator hose -> is it rubber?
    Russia Samara
    75
    Quote Originally Posted by CarGuy7a View Post
    I want buy two complects 5352R with aluminium pads. But Very long time for waiting packet from USA. I think use the leather for pads. For fst fix.
    Gurley, Alabama
    750
    Quote Originally Posted by Alexsy View Post
    Yes, it's a lower radiator hose for an old chevy van. I use it for many different things on my RC's.
    Russia Samara
    75
    Thanks!
    Where i can found radiator hose for an old chevy van in Russia ?? it is joke!! . I found fast solution from aluminum wired. All photo show tomorrow, because my wired for telefone on the work now. And wait official part now.
    Russia Samara
    75
    So as promised:
    It is my fast solution
    15,145
    Loving the thought and ingenuity put into this,
    Traxxas Brake Disc T-Maxx
    ^^^ Is what I use on my ERBE and Summit in place of the slipper pads. It yields a pretty big sweet spot and stands up well to brushless abuse.
    Alt-241 on the number pad =
    Russia Samara
    75
    http://buy.traxxas.com/product_info....oducts_id=7241
    Thanks!
    But wait from store.
    Russia Samara
    75
    Can you represent photo your solution? for experience.
    4,116
    Hey ksb, does the T-Maxx brake disk just drop right in? Is there any mods needed? Thanks!
    Sl2sh Slayer Summit Sl4sh 1/18 Rally/Teton T-Maxx
    Tanker 822
    9,410
    It should just drop right in. Maybe a little bit of mod to make the holes bigger. There's a thread or two or more in the other forums about this.
    15,145
    Correct. The holes need to be widened a little toward the outside edge of the disc. Depending on the exact thickness of the disc and the model's gear cover, some "clearancing" of the inside of the gear cover may be necessary.
    I've just checked the disc installed in my ERBE. Nice, even wear on the steel disk and the slipper-brake disk, which is showing every bit of its surface being swept. That's a lot more contact than any three slipper pads.
    Dec 2008
    Gettin' Lucky In KY
    3,861
    That looks great Alexsy. The thickness of the wire is near perfect fit.
    Thanks KSB for the brake disc mod as well.
    Russia Samara
    75
    Please explain my What this is KSB?
    Russia Samara
    75
    the wire thickness must be great pin on the gear wheel. i am use 2.5 mm - 0.1'
    Tanker 822
    9,410
    Though I applaud your ingenuity, I would not trust that wire with the sharp deformities on it as it will cut into the slipper plate. In addition make sure the correct thickness is used otherwise the spur gear will not sit evenly with the clutch bell and allow it to strip easier. Use something better designed for your application. I've had the same set of pads for 6 gallons now without an issue. When I first got into this hobby I read up on a lot of stuff before purchasing my T-Maxx and one of them was to put a dab of tire glue on the back of the pad and attach it to the pressure plate.
    If I didn't have a spare set of pads I would purchase the T-Maxx brake pad referenced above and use that.
    Russia Samara
    75
    I am do measure distantion between gear and friction disk. i am can`t saw different over 0.05 mm. And this solution for waiting official part from eBay. For Russion country i have 2 way 3 * price + shipping to russin daler or wait from USA :-( 3-4 week + shipping. Russion language have next
    sentence "Nude man is be very creative."
    My bad English.
    P.S i am replace to variant
    all pads
    Jul 2007
    Rc Room
    1,509
    I doubt you would have posted if your spur wobbled and spit out metal shavings. Good job making alternative parts Russian dude.
