Page 1 of 5 123 ... LastLast
Results 1 to 40 of 167
    Long Beach, California
    6,591
    My REVO-E build (take 2) :)
    well, here it comes again...... to build another one of my most favorite truck of all.....my REVO-E. I took some of my spare parts out of the storage box and I'm shock how much parts i have left.
    here are some of the gathering
    modified nitro chassis
    Tekno Motor Mount
    different angle shot
    here's what it looks like with ESC tray and battery tray installed
    if you have a revo 3.3 nitro/electric conversion the batt tray is located at the rear side where the tank was, mine is located more toward the front and mounted lower.
    as for my receiver box, it a small aluminum sheet bridging from steering servo mount to motor mount, it also gives a stiffness to the chassis.
    more parts and pics to come
    6,591
    parts that I need to complete are,
    F/R ERBE diffs
    F/R ERBE bumpers
    Summit (long shafts) driveshafts 4x
    turnbuckles/steering links
    push rods
    transmission gears
    slipper clutch assembly 3.3
    revo 3.3 geode wheels/tires
    platinum edition body
    wing/wing mount
    wheelie bar
    steering servo
    ESC/BL motor?
    maybe some more...
    so far coming in the mail are,
    Summit F/R a-arms
    primary shaft 3.3
    summit GTR shocks with springs
    6,591
    trans primary shaft 3.3 came in the mail today (6/26/13) and order some other parts off the list,
    turnbuckles set/push rods
    slipper clutch assembly with aluminum pads
    wheelie bar
    Australia
    3,259
    Nice to see you back mate...I need to get round to rebuilding my eRevo soon too...its in need of a good strip down and service. I will be watching your progress mate .
    Rock n Rolla !
    6,591
    Quote Originally Posted by MITCH316 View Post
    yeah mate, I figure I need something to go offroad. this one will be about the same as the first one with minor changes.
    6,591
    OK here's the deal, I am going to do some testing with my tranny gears, (nitro 3.3 tranny) I know the 2nd gear is 38t and top gear is 18t but I'm going to try XO-1 high speed gear bore it to 6mm and locked it on primary shaft then at the top input shaft is 22t. You guys think this gears might be a little bit too much for the motor? my spur gear is 40t and pinion 15t Mod1.
    | Rally GT8 Powered By CC | BackSl4sh Roadrunner |
    so cal
    505
    lookin good so far
    "That don't make NO sense!"
    6,591
    Quote Originally Posted by seanycool View Post
    lookin good so far
    thanks seanycool . OK its late, just got back from Disneyland . I received my Summit a-arms and suspension so I start putting it together and this is what it looks now.
    I like the summit a-arms because you can extend the rear.
    its coming along slowly but surely
    kansas
    7,862
    heeheee welcome back.....
    looking good as usual......
    rear might need some toe in....?
    6,591
    thanks, I need something to play here at the park while my boys playing at the playground lol. with my onroad car its to far away to watch my boys and play at the same time hahahha. as for the rear toe in....yes still need some adjustment, i'll get that fixed when all the parts are all here
    took out my XO-1 diffs so that I can use it with this build and to find out its just a regular slash 4x4 diffs, I e-mailed the seller not long ago now, I have to wait for their respond. that sucks!!!
    Jun 2010
    Miami, Fl
    6,731
    Looks good, just curious why did you choose summit arms, instead of rpm true tracks.
    6,591
    RPM don't make extended arms for summit, if they did i'll be all over it . I like the extended wheelbase which give me 14 1/2 inches, I wont run the revo driveshaft as it give to much stress due to the angle, waiting for the right moment to buy the summit driveshafts LOL.
    Jun 2013
    Idaho
    150
    Wait.... The slash 4x4 and xo Diffs are the same? Has anyone tried these in a revo and do they hold up to more power?
    Sent from my iPhone 4
    Summit
    6,591
    the difference between the XO-1 and slash 4x4 is that XO-1 diffs has an I bar inside now, with differences between XO-1 and ERBE is the size of the output shafts by 1mm (revo 6mm/XO-1 5mm). what I'm doing was swapping the output shaft and put my spare from my REVO.
    Jun 2013
    Idaho
    150
    So really the xo Diffs aren't that more durable if at all
    Summit
    6,591
    its durable for what its for, it doesn't go offroad or high jumps like the trucks do. you see XO-1 snapping axles before the diffs go out and that's on 8s.
    The Netherlands
    851
    Yep, the E-Revo diffs are the strongest diffs you are going to find in all of Traxxas's cars, still not enough for the E-Revo though.
    6,591
    Quote Originally Posted by WesleyK View Post
    its plenty strong enough if you only run it on 4s which is what i'm only planning of running it with but yeah they sure are one of the strongest diffs (ERBE/EMBE)
    6,591
    here's the pictures of my "thought" it was an XO-1 diff. getting ready to swap out the output shaft but now I have to wait for the real XO-1 diff before I can do everything and close it together.
    this is actually just a regular slash 4x4 diffs
    my spare revo output shafts
    difference between the 2 output shafts ends
    my spare ERBE diff cup but, as we know this don't come with the I bar, you have to buy them separate.
    Jun 2010
    Miami, Fl
    6,731
    Are the xo1 diffs, any different from erevo diffs?
    6,591
    no, just the output shaft (revo 6mm/ XO-1 5mm)
    6,591
    I went to the LHS to buy the diff internal gears, diff cup and outer diff case. ofcourse they only have one of each so I only manage to complete one diff lol. still waiting for the seller's respond from ebay for giving me the slash 4x4 diffs instead of XO-1, maybe tomorrow they'll respond my e-mail.
    then, I already have some pinion/ring gear. if the seller mail me the real XO-1 diffs then I can put that back into my XO-1 car
    6,591
    alright update about the XO-1 diffs, they're sending me the real XO-1 diffs (F/R) along with a prepaid envelope to return the slash 4x4 diffs, this is awesome!!!.
    also received some more parts today, REVO FOC kit, REVO pushrods (with blue rings), blue/silver REVO springs, and a couple of set of rockers P2/LT.
    as for the FOC, I got the lightened shaft, I drill the shaft to use a bigger pin to hold the gear, didn't like how small the pin was so, I use the one from the 17mm hex screw pin, I wanted to do the same to the primary shaft except, I don't have a drill bit that can penetrate thru the shaft, guys got any tip or what drill bit to use?
    Newcastle, Australia
    962
    Cobalt drill bits are used from drilling stainless steel. Very hard tipped so that might work..
    6,591
    here is my tranny 3.3 mod. XO-1 high speed pinion 34t and top gear 22t. on this pic I have 15t just for view
    need to be bore out to 6mm to fit into the primary shaft
    Mar 2013
    16
    We're did u get that kit
    6,591
    Quote Originally Posted by coolrcmodz View Post
    are you talking about the Tekno conversion kit?
    here you go http://www.ebay.com/itm/Tekno-RC-Bru...item53fa973435
    6,591
    received my Tekno 22T pinion for my top gear, what a like about this pinion is that it uses bigger grub screw than any regular pinion grub screws.
    now all I have to do is bore the 34T pinion to 6mm, got to buy a drill bit to penetrate this hardened pinion
    6,591
    finally got the 34T pinion bore out to 6mm and this tranny is ready for abuse
    also received my Summit driveshafts
    now I need to buy pair of long halfshafts.
    Jul 2007
    Rc Room
    1,484
    That looks like a good fit. I've always thought the stock gears were fairly robust to begin with but the pins snap. Did the grub screw land on a hole or a flat spot? Those metal on metal gears may wear rapidly.
    Norfolk, va
    1,167
    Ya, if those aren't hardened steel gears, then they will wear down abnormally fast.
    looks great though.
    ERBE, ERBE, Summit, Slash 4X4, Bandit,
    6,591
    Quote Originally Posted by BL-Bob View Post
    Quote Originally Posted by Zepher View Post
    looks great though.
    yeah I dremmel a flat spot for the grub screws and both gears are hardened steel.
  33. #33
    6,591
    got my platinum clear body in the mail today (7/8/13) along with the wheelie bar, still waiting for few more parts like the front diff, wing mount/wing, and wheels/tires (geode/maxx).
    as for the system to power this beast.....still undecided.....
  34. #34
    kansas
    7,862
    coming along nicely.........
  35. #35
    Australia
    3,259
    Looking good...Nice one mate .
    Rock n Rolla !
  36. #36
    6,591
    Update, well I don't have anything to update since my XO-1 diffs isn't here yet so, I email them back, I ask them if they mailed it and now I was told that since I didn't respond to them that they didn't send it out. I didn't respond cause I assume from their respond was "I’m very sorry about that. We will send you an XO-1 differential with a prepaid return mailer for the Slash 4x4 differential."
  37. #37
    El Cajon Ca
    1,804
    Well your getting close to completing your fine project, can't wait to see the completed truck....
    "enjoy your ride"
    Dennis
  38. #38
    6,591
    Quote Originally Posted by orca44 View Post
    thanks, I cant wait to get it running again, forgot how it feels to run a MT. went to LHS to buy some lexan spray paint (3 cans), prep the body tonight and will start painting it tomorrow.
  39. #39
    Jul 2013
    Uk
    24
    I know nothing on this subject but from experience guys how does a erevo brushless edition vary in performance,durability and feel to a brushless converted revo? I know there are many parts that are the same but theres still a reason why alot of people still do conversions.
    Really like the look of a conversion revo but for now my plastic revo is doing just great
    Erevo with xerun brushless system
  40. #40
    6,591
    Quote Originally Posted by Sithercguy View Post
    the weakest part of the nitro are the diffs and tranny other than that its very durable.
