Results 1 to 12 of 12
    PM me if ya wanna bash at Greenwood Bashplex!
    13,046
    Who runs a sensored 550?
    Looking at the tekin 5.5 4 pole sensored on an mmp for some track work as a truggy. Any other suggestions? I will be running sct tires and rims...
    Wales in the UK
    5,213
    Hi rag I am running a hobbywing pro sct 120a esc and the tenshock sc411 3500kv sensored setup and its awesome and I have been smashing it hard for over 10 months and run it on 2s and 3s .......peace
    Dec 2009
    MN
    785
    Honestly, the Redline SC4X 5.5 is a out dated motor, compared to the PRO4 540 motors. I run the 4000kv in a slash 4x4, geared for 35mph on a 30sec. track. Regardless of the motor you purchase the firmware you choose makes a big difference. I suggest comparing 1.32 (wild) 1.45 (mild, more lingerer) depending on the traction at your track. JMHO
    Slash 2wd
    Slash 4x4 MT
    P4de Trail
    13,046
    So which 4 pole 550 motor for a pede truggy running in 75% loose surfaces on a track?
    Dec 2009
    MN
    785
    From what I have read, some like the new 550 HD 3500kv for a tight track, and others prefer the 4300kv for larger tracks, the motor likes to be geared up two teeth on the pinion, from the stock gearing. While others are disappointed with the HD motors, on getting the power to the ground, just too much power for the track conditions.
    Slash 2wd
    Slash 4x4 MT
    P4de Trail
    13,046
    I found that motor for for 147$ shipped. I may go for it...
    Nov 2011
    Austin, Texas
    970
    Pro4s sell fairly cheap used. I picked up one for my wraith for 70 or 80.
    Sent from my phone.
    13,046
    Is that the 550 HD?
    Nov 2011
    Austin, Texas
    970
    No. The one I picked up was a 3300kv Pro4, non-HD. If it can move a 8lb Wraith with 5.5in soft tires at 20+ mph all day, it should have no problem in a pede at the track. The 3500 and 4300 HD are only rated for 2S, just so you know. The longer HD can would help with potential heat issues though.
    13,046
    I want a 4 pole, those are 2 pole.
    Nov 2011
    Austin, Texas
    970
    They are most definitely 4 pole or they would get destroyed in a Wraith. And they have the same 18.5 rotor as the HD.
    http://www.teamtekin.com/pro4.html
    4 Pole 12 Slot Hi-torque Motor Design
    CNC Machined 6061 T6 Billet Aluminum Heatsink Can
    Neodymium Sintered Magnets
    Rebuildable Design
    High Purity Copper Windings Maximizes Efficiency
    Precision Engineered for Maximum Energy Conversion
    Dual-Plug Sensor Wire Harness for use with all sensored and sensorless systems
    High RPM ABEC5 Oversized Bearings
    Wales in the UK
    5,213
    Dude look at the tenshock sc411 550 motors they are awesome trust me......peace
