Results 1 to 24 of 24
    Nov 2011
    Austin, Texas
    970
    Ultimate Hex Mod
    We are all sick of stripping hexes. It's one of the worst feelings, because you know the work and money involved in removing the tire, buying new wheels, just to do it again. I have been gluing my hexes in and it worked until this week when I finally stripped one. Other's have turned to upgrading to 17mm, but that's not cheap and wheel selection is limited, not to mention modding the wheels and/or tires. Here is my solution, which only takes 15 minutes or less for all four.
    One stripped JConcepts Rulux, a 12mm hex and an M2x6mm cap head screw.
    Using a 5/64 bit, drill a hole through the side of the hex perpendicular to the pin notches (see last photo in post). It must be slightly forward of center.
    Screw in your cap head screw just until you see it poke out in the hole. You want it flush on the inside.
    Using an exacto or box cutter, notch your wheel hex. Smaller is better. It's easier to widen it as needed. Go all the way down to the flat part inside the hex.
    Insert your newly modded hex. It should sit flat in the wheel. Use an L wrench if you need to tighten the screw down a bit. Just make sure it's not sticking out in the hole. You could put another screw on the opposite side for extra strength and security.
    *THIS MOD MAY NOT WORK WITH ALL WHEELS
    Michigan
    1,107
    That's a pretty creative method to solve the problem. How long have you been running with that mod? The problem I'm having with my pede is that the only wheel attached to a metal mip hex is the only one that strips.
    Stampede 4x4
    Anza Slash VXL
    Rustler VXL
    Rotterdam, Netherlands
    7,311
    Very creative indeed. And the MIPs are the problem creators on my Pede too. Maybe get some 1/16" screws instead of the 2mm ones.
    McKinney, Texas
    811
    Will definitely use this and experiment on my talons. Thanks
    Riverton Utah
    4,357
    Just a thought, but could you put in 2, 3, or even maybe 4 screws in to make it stronger?
    Nov 2011
    Austin, Texas
    970
    You can only put in two or you may interfere with the pin notches. I guess you could if you were very careful. Honestly, one is very strong. The screw would have to tear through all that plastic to fail.
    Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
    Marshal Dadx2mj's Avatar
    Aug 2007
    So Cal
    21,254
    I wonder how much it effects the balance of the tire/rim,,,two screws 180 from each other might help balance it out a little.
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
    Nov 2011
    Austin, Texas
    970
    The screw is so light and its so close to the center, it has no effect in my testing. The wheel spins without wobble and the trencher is so heavy that I cant see it impacting the balance. Two screws is probably ideal, but I'll keep testing with one.
    Sent from my phone.
    Wales in the UK
    5,446
    Dude awesome mod but I would use two screws 180 degrees apart just so its bulletproof and even the weight out.....peace
    United Kingdom
    623
    Genius. If there were a 'Like' button it would have been hit.
    May 2013
    351
    Couldn't you just Glue them in?
    575
    You can, but you'll have to do that before the hexes are rounded. This is for after they are toast.
    Nov 2011
    Austin, Texas
    970
    These were glued in. They lasted a couple months and then stripped. You can do this mod with new or stripped hexes.
    Sent from my phone.
    Wales in the UK
    5,446
    And if you do both they will be even tougher again...........peace
    so cal
    505
    wow i just did this mod to four of my wheels and it was extremely easy to do. i'm so happy i don't have to unglue the wheels and go through all that.
    "That don't make NO sense!"
    Nov 2011
    Austin, Texas
    970
    After more testing, I recommend two screws per wheel, especially for high powered motors.
    Sent from my phone.
    13,148
    I am planning to buy tekno ft shafts. Not sure if their hexes with the 6mm inside diameter are metal? Will there be enough material for the screw to grab???
    Like the mod!
    Nov 2011
    Austin, Texas
    970
    The included hexes are plastic. You can buy aluminum Tekno hexes. The plastic hexes are a hair smaller than traxxas unless they changed them. They are very easy to strip. I usually drill out traxxas hexes to 6mm.
    While this mod works. I think its better suited to new or unstripped hexes and wheels as a preventative. On some completely stripped hexes, I tore the screw out of the hex during a big bash session. I will try to drill and tap aluminum hexes at some point. I also want to try the wide rustler hexes since those should give more meat for the screw to hold onto.
    Sent from my phone.
    Wales in the UK
    5,446
    Thanks for the tips dude I thought two would be the magic number.......peace
    Oct 2012
    Easton, MD
    599
    Doing this mod with some cheap aluminum hexes. Drilled out to fit my 6mm tekno axles. They came with grub screws, but I replaced them with short screws. Just have to remember to pick up some epoxy tomorrow.
    Sent from my HTC6435LVW using Tapatalk 4 Beta
    Jun 2013
    Stuttgart, Germany
    138
    briandee that turned out nice!
    Wales in the UK
    5,446
    Dude give us a review after a few runs I would like to know how it turned outMy epoxy rubber resin with aluminium hex mod is still working but as so as it fails I am going to do this mod..........peace
    Oct 2012
    Easton, MD
    599
    I'm waiting on a few parts to come in. I just switched to Tekno axles with their 17mm adapters because I was tired of stripped hexes. However, there are not many options in wheels and tires in the stock size. Once I get the rest set up I will report back on durability.
    83
    Thanks for the idea, I've done this on the rear wheels on my pede, has been great for about 5 3s packs so far. Don't think i'll be switching to 17mm anymore
