Results 1 to 14 of 14
    Jun 2013
    Auburn,Alabama
    21
    Shredded clutch bell
    So if you run a steel spur gear, or are thinking about getting one, watch out for this. It apparently wasnt the mesh like a thought it was, ended up being i had my slipper set to tight. ha some how i had an extra clutch bell so i can still drive tomorrow. but dang this is just nasty.
    Mar 2007
    Michigan
    293
    If you run a steel spur gear, you have to run a hardened clutch bell as well. Otherwise,^^^^^will happen every time.
    Oct 2005
    South Florida
    18,548
    +1 Your regular stock clutchbell will not hold up to a hardened steel spur gear...
    Founder of H.U.A.
    Hop Ups Anonymous
    May 2013
    Goldsboro, NC
    89
    so after this how does the spur gear look???
    May 2013
    Goldsboro, NC
    89
    I'm running a RR 19T cb with a stock 54T spur......no problems yet. Which I run the slipper slightly loose. I play in mostly diRt.
    Jun 2013
    Auburn,Alabama
    21
    Well the spur gear looks like this no problems at all. my slipper is super loose now, cuz i dont wanna do it again. However if i get the money i will probably buy a hardened CB just to save some time and worries down the road.
    Jun 2013
    Auburn,Alabama
    21
    And just for some of my own knowledge, anyone out there that is running a steel spur gear. What clutch bell do you have and how many turns out from fully compressed is your slipper? just curious
    "Speed costs money, how fast do you want to go?"
    Gurley, Alabama
    766
    The problem with running a hardened steel clutch bell and spur is the next weak points in line are inside the transmission. BUT, I have an all steel driveline from the clutch bell to the wheels and couldn't be happier. Haven't had anything break, strip, or twist yet and I guess I'm about as rough on these things as you can get. I have no mercy.
    Oh yea, I keep my slipper tight enough that it will only slip under extreme loads, but I use different slipper pads than anyone else. So my slipper applications don't really apply to anyone else.
    May 2013
    Goldsboro, NC
    89
    to set my slipper I always set it loose....so it WILL slip, then gradually turn it in until its at the desired point. If it stops turning (all the way tight) back it out an 1/8t or so. Like Mark said, if you run it all the way tight, with hardened gears, next it'll be your trans. Robinson Racing makes a good cb and in a lot of sizes. http://www.robinsonracing.com/catalog/catalog.html#
    Jan 2008
    Sugar Hill Ga.
    8,383
    Quote Originally Posted by IdriveAjato609 View Post
    The slipper setting will not save the stock bell from being eaten by the hardened steel spur. With a perfect mesh the stock bell may last for a while; if its not perfect, it will look like the bell in the 1st post in short time.
    Jun 2013
    Auburn,Alabama
    21
    I know for right now it seems to be doing fine, i ran it quite a bit and all seems fine for now. however im sure after a while it will look like the first one and if so i may be a new hard cb or buy a nother stock one and go back to the plastic spur gear. rather replace those then destroy something else more expensive in the drive line.
    May 2013
    Goldsboro, NC
    89
    I agree....thats why I run the stock plastic spur gear. I have another just in case, but haven't had to use it yet. Its been a year and a half.
    Oct 2005
    South Florida
    18,548
    The Spur is hardened steel the stock CB is not.... If you are going to use a steel spur you need to get a hardened steel CB and that won't happen...
    Founder of H.U.A.
    Hop Ups Anonymous
    Jun 2013
    Auburn,Alabama
    21
    I ended up going down to my LHS and bought a couple plastic spur gears. When they are as cheap as they are id rather burn through those then burn through clutch bells or pay the extra money for them.
