Thread: T Maxx 3.3
    T Maxx 3.3
    I started my T Maxx after about three weeks it went to full throttle what would cause this
    Apr 2013
    469
    trigger pulled all the way back in transmitter would cause it.
    126
    Your vehi0cle could have lost connection with your transmitter and caused it to go to WOT or a linkage could have came loose or broke. Check over the vehicle and see if the radio will control the throttle without the engine running to find your problem area.
    Jul 2013
    6
    I just bought a new Slasher about 3 days ago, on first start it went wide open. Pulled off air filter and my carb was set half open from factory. Pulled of the lever and reset to 1mm. Runs great now.
    SE Lower Michigan
    249
    Usually when it goes WOT the batteries are low and the servo goes to WOT.
    Scott
    4909 MAXX 3.3
    4910 MAXX 2.5
    103
    if you want to prevent that go with digital servos it really helps (check your pm messages and I will give you links to some of the best for me).
