Results 1 to 7 of 7
    572
    cycle / use ????
    Long term lipo storage question. I have read that every few weeks you should cycle the batteries.
    There at storage voltage. I have an ez peak plus
    Do I A: Discharge the pack, then full charge the pack, then storage voltage the pack?
    B: Full charge the pack then storage voltage?
    C: discharge the pack then storage voltage?
    D:none of the above ?
    Alma, MI
    12,279
    Probably A, but I do D. lol
    I had a set in storage for a year... and only checked on them to make sure voltage wasn't dropping too far.
    298
    I've read you don't need to cycle Lipo batteries...I may be totally wrong there
    15,442
    The chemicals can go inert if you do not use the battery. Just about every rechargeable battery fares better when it is used regularly. Every 6 weeks is a good target for cycling. I would at least fully charge (or to 4.1V/cell) the packs and then bring them back down to storage voltage.
    Alt-248 on the number pad =
    May 2013
    37
    I'm going to bump this discussion as I am in the same boat. I have quite the collection of lipos and some don't get used as much as others.....
    Should I be cycling these every month or 2 like stated above?
    Does the maH determine the frequency I should be doing this?
    friendswood texas
    1,234
    With work I am very limited on run time then the weather throws a monkey wrench in it. If I can't run I will C&S every 4 weeks.
    Alma, MI
    12,279
    mAh does not change the frequency, no; usage is usage.
