Results 1 to 22 of 22
    AL
    164
    What tires to get next?
    Two weeks was all the anaconda could take.
    So what tires are better? And the same size as the stock anacondas
    Riverton Utah
    4,351
    Maybe you should rotate the tires before one blows...
    AL
    164
    Maybe if they weren't directional tires I would have.
    Riverton Utah
    4,351
    Oh, I meant put the front left tire on to the rear left tire, and the front right tire to the rear right tire, etc.
    Riverton Utah
    4,351
    So, are you looking for on road tires, or both on road and off road?
    On Road: http://prolineracing.com/tires/stree...-black-wheels/
    Off Road: http://prolineracing.com/tires/dirt-...-black-wheels/
    AL
    164
    Rear tires are hex and the front ride on bb.
    I'm looking for on road tires.
    Riverton Utah
    4,351
    AL
    164
    What are the size difference in the 2.2 and 2.8 compared to the stock size.
    I like the road hawg 2 and the road rage2
    Riverton Utah
    4,351
    They are both some what the same size when the rims have tires on them. 2.2's have more sidewall area, but less rim area. 2.8's have less sidewall area, but more rim area. Here's a link that might help. http://www.rcuniverse.com/forum/m_10...m.htm#10826903
    May 2013
    THE GUSHINE STATE FL.
    53
    It's more than side wall. 2.2 tire is going to run a higher rpm because the tire is smaller in diameter. With the 2.2 and the 2.8 tire next to each other the 2.2 is about 1/8 t0o 1/4 smaller than the 2.8 tire. I have both and like the 2.8 much better. handling and performance is lost with the 2.2.
    JATO, MERV, 4-TEC, & NITRO-VEE
    Gurley, Alabama
    766
    Yea, what he said. The 2.8 Road Rage's are the closest in size to the anacondas.
    AL
    164
    Think ill look into the 2.8 street fighter or the 2.8 road rage. But does anyone know how they holdup?
    Chicago, IL
    247
    Quote Originally Posted by jwc0108 View Post
    Hold up pretty well but really depends on your driving, if you spin the tires needlessly then they won't last long... They hook up well for speed runs though... I am about to do the 17 mm conversion so that I could use buggy wheels... Also, you can look into some jaco foams as well...
    Gurley, Alabama
    766
    I have the street fighters and road rage's. The rr's are better for cornering and speed runs and the sf's added with a slightly larger spur makes the Jato quite the wheelie machine.
    80
    I have JACO foams. As long as your running on a fairly warm/hot surface they're great. Cold/wet=forget about ANY traction. I also have ancacondas, which are horrible and don't last. Also have streetfighters, which are great for any street running. Keep in mind they are bigger tires and will require spur gear changing.
    AL
    164
    yes the anacondas suck as u can see. ive been looking for the road rage 2.8 w/ wheels but hard to find so far
    AL
    164
    does anyone know where i can find this tire/wheel
    http://prolineracing.com/tires/road-...tires-mounted/
    May 2013
    53
    231
    Are the Pro-Line Street Fighter tires a direct fit to the Jato? No other modification needed for the Jato for work well? I'm thinking of getting those, or what you guys think? Are the Road Rages better? Why?
    AL
    164
    Well I can't find any road rage 2.8 on desperado wheel.
    So I got these
    http://www.ebay.com/itm/281087259594...84.m1497.l2649
    So what's the best way to remove the old tires off the wheels I have
    Feb 2013
    houston
    235
    get some pl trenchers
    May 2013
    Goldsboro, NC
    89
    your HS should have some CA debonder, or use the boiling method. Someone on the forum said they used a syringe and acetone (nail polish remover) and used the needle to get in there. Sounded good.
    Also, I have the road rage tires on my RC10T3, and I spin around a lot, no signs of wear.
