Results 1 to 2 of 2
    May 2013
    South Texas
    6
    Thanks Traxxas!!!
    Well almost got through installing all of my upgrades without any major issues until I tried installing my rear sway bay. The two 3x15mm screws on my lr rocker were over tightened at the factory and stripped out the rocker when I removed them. Anyone have any easy fixes or am I going to have to replace it? Other upgrades included 17t clutch bell, center diff and rear brake kit. Those went on with out any issues.
    Dec 2008
    Gettin' Lucky In KY
    3,876
    I had a couple like that also being over tightened. No problems though. If it's not stripped out too bad you can put a dab of CA glue on the threads of the screw and run it in and let the glue setup. It's kind of like loctite for screws that go into plastic.
