Results 1 to 18 of 18
    Jul 2011
    Sioux City, Iowa
    189
    Confused?!? About new motor
    I'm replacing the motor in my revo. The new motor's crank is shorter than the one I took out. What do I need to get the flywheel and clutch on the end of the crank
    Jul 2011
    Sioux City, Iowa
    189
    Jul 2011
    S. Jersey
    716
    You need a different crank or u can swap it with your old one.
    Jato 3.3, Revo .28 JL Max, Nitro Stampede 3.3
    Jul 2011
    Sioux City, Iowa
    189
    Idk about using my old one. I will buy a new one. Thought there was an adapter or something. I found two screws i don't know what they are for any ideas?
    Dawson creek bc
    1,115
    There's a nut tht threads on the crank. Take it off your old one. It's a IPS shaft.
    Jul 2011
    S. Jersey
    716
    Dawson creek bc
    1,115
    Dec 2008
    Gettin' Lucky In KY
    3,880
    You got the motor with the multi shaft crank. I went through the same thing. I ERP my 3.3 and the guy at the LHS accidently ordered me that same motor. I had him send it back for the IPS shaft motor. Where did you get the motor from? If you got it from a LHS take it back and tell them it's the wrong one and see what they can do.
    Jul 2011
    Sioux City, Iowa
    189
    I bought a jato last summer and I got the motor NIB with it. I ordered the ips crank that I will put in. . Does the sleeve need to come out to get the crank out?
    Putting the water on the hot stuff
    9,705
    Doesn't need to come all the way out, just high enough that the rod can clear.
    Jul 2011
    Sioux City, Iowa
    189
    Should I oil or grease bearings/crankshaft?
    Gurley, Alabama
    766
    Quote Originally Posted by 1_handed_bandit_green View Post
    Just coat everything with after run oil.
    Jul 2011
    Sioux City, Iowa
    189
    There is red greasey looking substance in the crank case. I plan on spraying it all down with wd40 but do they put a grease in it at factory?
    Jul 2011
    Sioux City, Iowa
    189
    this is a new engine but I don't know how long it's been sitting. I'm thinking its just deteriorated oil/grease but I'm not totally sure with it being chunky
    Jun 2009
    Cocoa Florida
    3,941
    I would Q~tip the gunk out then spray it out good, make sure the bearings run smooth, then put it together & run it.
    Look out for the tree/crunch!
    LiPo? Naw NITRO!!
    May 2013
    Iowa
    15
    you did not need to buy a new crankshaft.. the screws that you pictured one would screw into the end of the crankshaft then there is another part (I don't have the # handy) that screws onto it to tighten the flywheel and hold the clutch assembly..
    I would get some nitro cleaner or I've used brake parts cleaner or carb cleaner any would work to clean that engine out.. then lube the bearings with some 20-50 synthetic oil and spin them a few times and put a drop of that oil on the crank as you assemble it, as well as the rod, wrist pin and so on..
    Jul 2011
    Sioux City, Iowa
    189
    Thanks a lot guys. Getting her running and broke in this afternoon
    Oct 2005
    South Florida
    18,514
    Quote Originally Posted by slopoke101 View Post
    +1 you just needed the flywheel adapter nut part # 4144
    http://buy.traxxas.com/product_info....oducts_id=6471 It's about $6.00
    Robin Williams
    He will be greatly missed...
