    Mar 2013
    401
    traxxas connectors
    how many amps are the traxxas connectors rated for?the reason i am asking is i am ready to put a 180 amp esc in my spartan boat and i need to decide what connector to put on it.
    Alma, Michigan
    12,291
    You are good to go... I have pulled 200 amps (I think) through mine without them even warming up.
    The reason I say "I think" is because I do not have a watt meter... but the 200amp constant battery that was being used was warm, meaning it was probably being used to its capability; unless it is improperly rated. However, it was in an 1/8th scare RC that is known to pull that kind of amps, so it could be accurate.
    Edit:
    Warm = 100-115F
    Norfolk, va
    1,167
    If we use Jimmy's example, then they are good for 400amps since my spc batteries are rated at 410amps continuos and I got the batteries quite warm in my erevo.
    ERBE, ERBE, Summit, Slash 4X4, Bandit,
    Mar 2013
    401
    ok thank you both for your help
