Results 1 to 17 of 17
    Vancouver, WA
    200
    Traxxas CVD's - Is this normal??
    I while back I bought some used CVD's for my E-maxx from this forum. I installed them and this is how they are currently. I have never had any problems, but was wondering if this is normal??
    Thanks
    Jul 2012
    wyoming
    567
    just went and looked at my emaxx, it has the cvd's and rpm arms as well, the pin throught he shaft is about half way. Where as the pin on yours is right on the edge. Something seems to be off in your rig.
    kawasaki summit, revo& slash; regular rusty, pede
    Dawson creek bc
    1,115
    If you have problems with it popping out you can screw your pillow balls
    In further. It will make for a nicer fit
    Vancouver, WA
    200
    Which pillow balls? I have TruTracks in the rear.
    Aug 2012
    Albany, New York
    462
    Can someone post a picture of how they used a small rubber o ring to house the dogbone in the drive cup better? So far all the materials I used fell out and didn't hold the ball in the cup that much better
    Dawson creek bc
    1,115
    Fuel tubing works well with dogbones. Since the CVD's use a stub axle on the other side o-rings will not help at all
    Vancouver, WA
    200
    @Kyleb: If you can explain to me what you are talking about that would be sweet . What are the o rings for??
    Also can someone tell me the length of a Traxxas CVD is (from differential to wheel, with out the stub axle. Just the dog bone).
    Thanks
    Alma, MI
    12,281
    Does it stay there through the entire cycle of the suspension?
    Dawson creek bc
    1,115
    Quote Originally Posted by nikzak View Post
    Thanks
    You can use o-rings or fueltubing to center a dog
    Bone. It will not help situation at all.
    561
    I found another part number that I think will work....TRA 3654. It has 2 pins in it.
    561
    Oops, wrong post.
    173
    the true track rear end is a little longer that is why your shaft is so far out. GO RPM!!
    Alma, MI
    12,281
    He has RPM...
    173
    Yes he has RPM, the trutrack rear suspension
    Cumming GA
    251
    Get the traxxas extended drive cups,mine was the same way and actually popped out.Since the longer drive cups no problems at all.
    Brookline, NH
    1,186
    Traxxas extended drive cups #5153R
    Jan 2010
    mid michigan
    540
    i have the ture track on my tmaxx with the traxxas cvds and u will have to get the extended revo cups or a ue diff cup the ue diff cup is almost 1mm longer than the extended revo cups i found out the hard way and blew a cvd out of the cup at about 45-50 and it did not go well
    men drive nitro
