Results 1 to 10 of 10
    Apr 2013
    469
    anyone modify blue glow plug wire to make it easy.
    anyone modify the blue glow plug wire to make it easy/tool less to remove and insert into the glow plug.
    muscoda, wi
    1,244
    honestly i tossed the blue wire, and bought one of these. they even test your glo plug. also by tossing the blue wire saves more battery for the starter. peace
    http://www.ebay.com/itm/Du-BRO-E-Z-G...item3f25654eef
    Tanker 822
    9,409
    Yeah, use a glow ignitor and pull start.
    Woodward, OK
    419
    I put a piece of heat shrink about 1.5" long on the wire. It makes it stiffer, so you do not need pliers to plug it in. also protects it some around the top of the head.
    T-maxx 3.3
    Rusty 2.5r
    Summit VXL
    Nitro 4-tec
    Apr 2013
    469
    will do the heat shrink "mod" on a new wire...
    Feb 2013
    132
    I have heat shrink on mine too. A out 4 or 5 layers in.. I can pull, push... No problems at all
    Sent from my SPH-L710 using Tapatalk 4 Beta
    May 2006
    Dayton Nv.
    3,181
    Before I went to the glow igniter I went down to the hobby store and bought some K&S copper tube just big enough so the small end of the spring would fit inside (sorry I don't remember what size it was) soldered the spring in and cut it just long enough to clear the head then soldered the blue wire to the other end then covered it all with heat shrink tube.
    Oct 2005
    South Florida
    18,370
    DId you forget to warn any EZ start user they better know how to tune? If not they will suffer blisters between the fingers?
    Yup, go with a glow ignitor and pull start, when you have your tune down there will be less to carry, your TMAXX will be lighter and more air flow around the engine when running... Lot's of plus's there..
    Now there's another thing you can do to protect the Blue wire...
    Some models you can install an aftermarket wing, if you flip the blue wire AND the engine will not get ripped up... Also you have better in air handling as well as a nice handle... Multi Purpose..
    Another trick is to get zip ties and put them on the top of the cooling head, push the blue wire below them and they will be protected as well.
    Lastly, heat shrink tubing. Put a few sleeves of it over the blue wire shrinking them one at a time to act as a protective coating... As that get's torn up you just replace them.
    Founder of H.U.A.
    Hop Ups Anonymous
    Dawson creek bc
    1,108
    ^^. You can also splice open a peice of fuel tubeing and zip tie it around the blue wire.
    Dec 2006
    4,349
    I'm using a power connector from a hard drive:
    He who dies with the most toys wins !!!
