Results 1 to 19 of 19
Thread: Alum toe links
    1,161
    Alum toe links
    Are the ends of the aluminum toe links less prone to poping off over the stock? Had a rear pop off for no reason today. Wondering if I should just order stock replacement ends or upgrade?
    1,161
    I just realized they don't come with ends. Guess ill just order a couple bags of stock ends
    Sep 2009
    Victoria B.C Canada
    5,078
    Been sorta looking for something a bit more durable.i wear the plastic part out
    Allowing it to wallow around the ball ends.toe and camber goes out of wack.
    At least they are not expensive.
    Sent using lipo power
    Mountains cant stop me
    they have tried
    1,161
    Mine were showing no signs of wear. I clean and lube them every run. Not sure why they pulled out of the thread I was running a strait line stopped and the tire was facing south. Hehe. Pulled out 2 more times on the way home same driving.
    Ya at a couple of $ a bag cheep to replace
    Jul 2012
    Saint Louis, MO
    504
    Try the rpm ones.
    Sep 2009
    Victoria B.C Canada
    5,078
    In this case the rpm are no better as far as wear goes
    they have tried
    1,161
    ya i have read a few posts where they have pulled apart as well.. rc4wd has some available but don't see the correct size.. i have seen them at one of the local industrial supply stores at roughly the same size.. gonna have to go do some shopping when i get time.
    1,161
    looks like Hot Racing has everything im looking for..
    1,161
    alright what is the difference between the 5348 rod ends for the rear toe and the 5347 rod end that is used every ware else on the truck including the steering. They all look identical in size?
    Sep 2009
    Victoria B.C Canada
    5,078
    Ball ends are different in the rear.
    I believe it because of the 11 mm that swept back rear arms have
    they have tried
    1,161
    The front steering have the same offset. But have the same part number as all the rest
    Sep 2009
    Victoria B.C Canada
    5,078
    The rears are summit specific they have a ring on them to tell you that.not totally sure why.
    they have tried
    1,161
    Well got a bag of the ones used every ware else on the truck I cannot see any difference other than the ring
    Sep 2009
    Victoria B.C Canada
    5,078
    I have used other ones when I needed to
    they have tried
    1,161
    Ya that's what I'm doing as their is no difference.
    Sep 2009
    Victoria B.C Canada
    5,078
    Hey a contest "what's the difference"
    I'm gonna check that out,curious now.lol
    they have tried
    1,161
    I wonder if traxxas even knows what the difference is. Hehe
    1,161
    Ok here is the only difference I can see. Around the pivot ball their is a little more plastic not that much but a little. Got me as to why this is the only area on the truck to use these ones
    Sep 2009
    Victoria B.C Canada
    5,078
    My guess is the summit arms, being slightly different than the revo arms
    (Longer wheelbase)on the summit
    Maybe why.thats all I got. Lol
    they have tried
