Results 1 to 10 of 10
Thread: Fuel leak
    Apr 2013
    Portugal
    85
    Fuel leak
    My revo doesn't work because have a leak somowere in the engine. When I connect EZstart the flywell spins and splashes fuel everywhere. Anyone know what it could be?
    I do not want to disassemble the engine without knowing something ... is the first time that I will disassemble it .
    Help please
    Riverton Utah
    4,416
    Try checking the engine bearings, it sounds like one of the bearings is going bad.
    9,844
    Is your fuel line connected to the carb? Carb cracked or not? The only other spot would be the front bearing has a good leak but if it is a considerable amount of fuel look at the first two options.
    Apr 2013
    Portugal
    85
    Fuel line connected and carb OK. Already disassembled the engine and it seems that is the front bearing because the center bearing moves up and down a bit ... how do I take it off?
    I've tried and it seems to be too tight or maybe I'm doing wrong , have you ever replaced it?
    9,844
    Take a socket small enough that will fit through the rear bearing but large enough to rest against the front bearing. Then use a mallet and tap the front bearing out. The rear bearing requires a stripped down engine to head to a 325 oven for about 10 minutes then the rear should fall out.
    Apr 2013
    Portugal
    85
    Done...I hope to get the problem solved
    Thanks for the help
    Apr 2013
    Portugal
    85
    To take off rear bearing I used boiled water, put the the part where the rear bearing is in hot water over 2minutes... was enough
    Feb 2013
    566
    Did this fix the problem?
    Apr 2013
    Portugal
    85
    Yes the rear bearing came out with no problem (the bearings were full of gaps)but I'm still waiting for the new bearings. Takes about 15 days to get here, should arrive next week
    Feb 2013
    566
    Cool, I know some of these places take their time lol. But it's worth it.
