    May 2013
    Erie, PA
    602
    Charging current?
    If a battery states that it can be charged up to 2c, means that i can charge up to double the current, which should allow the battery to charge quicker right? in example.... a 5000mah battery can charge at 10 amps?
    Alma, MI
    12,280
    Yes, your math is correct.
    But keep in mind that just because it can be charged at 2C, doesn't mean the pack will last the longest at 2C.
    I have packs that can be charged at 10C, but I hardly ever go over 1C with them because I want them to last.
    May 2013
    Erie, PA
    602
    and by "last" do you mean, run time or life expectancy? or both?
    Alma, MI
    12,280
    Life expectancy.
    Possibly run time... but I imagine if so only a little.
    May 2013
    Erie, PA
    602
    thanks for your advice jimmie. another quick question. I see that you advise to store your lipos at 3.85v per cell. My charger will not charge to storage levels. My esc low voltage cut out is around 3.75v I stopped running a bit early and checked the volts. they were at 3.87. Is that a safe way to get my cells at storage level? or is there a better way? thought about watching the volts as it charges and stopping the charge. your advice is much appreciated.
    Alma, MI
    12,280
    That is an acceptable method... although you are cutting your run time quite short.
    As long as you will be using the batteries within 3-4 days anywhere between 3.6-3.9 volts per cell is acceptable.... however you decide to get them there.
