Results 1 to 30 of 30
    Sep 2012
    sacramento, ca
    742
    Shredded slipper pads!
    Anyone shredded their slipper clutch pads before? I was in the middle of an epic bash session at the local park and noticed I Didn't have front wheel drive. The grub screw keeps coming out of the front center shaft. So I was doing 1/4 - 1/2 throttle doughnuts after that. Suddenly I had no power to the rear wheels too! Thought I tore up my tranny. After I got home, I split the tranny and fount the gears were fine. So the problem seems to be this...
    Whew! It definately coulda been worse. I'm thinkin my slipper was too tight. What do you guys think?
    addicted much....
    Brookline, NH
    1,101
    I think you should get this. These pads wont fall apart.
    http://www.ebay.com/itm/Traxxas-5352...item43b314e2d3
    Sep 2012
    sacramento, ca
    742
    Hey that's a very reasonable upgrade. Ill try it. Thanks for the link.
    addicted much....
    Sep 2012
    sacramento, ca
    742
    Quote Originally Posted by EMAXXBRUSHLESS View Post
    Ok, ordered it up! Thanks maxx.
    addicted much....
    Jun 2010
    Miami, Fl
    6,731
    I broke the slipper, and got the Robinson racing one, it cost more, but it is worth it, also the double slipper from HR is good.
    Sep 2012
    sacramento, ca
    742
    Wow, how'd you break the bracket? Was it defective?
    addicted much....
    Jun 2010
    Miami, Fl
    6,731
    I would like to know..have no idea. It was noisy, and I thought it was just loose, but after tightening it, the slipper was woobeling all around.
    Sep 2012
    sacramento, ca
    742
    Probably just made of cheap pot metal or something.
    addicted much....
    May 2005
    Chatsworth GA
    101
    I currently have a cracked pressure plate as well. I keep cooking the aluminum slipper pads. On 6s they just will not hold up tp the power. I always crank my slipper nut down as tight as I can get it anyways, so does anybody know of a slipper clutch eliminator? Like used in r/c crawlers?
    Riverton Utah
    4,127
    Bad, Bad idea. The slipper clutch saves you drive line from shock and rough starts and stops. Taking it out will result in some thing else breaking.
    Sl2sh Slayer Summit Sl4sh 1/18 Rally/Teton T-Maxx
    448
    Finisher, I was wondering what was the P/N of the motor gear you needed for this new slipper set-up. I also found out that you can get new bearings and pads. I understand the P/N's are 7851 and 7980.
    Jun 2009
    Cocoa Florida
    3,808
    Quote Originally Posted by Ninja View Post
    Get a HotRacing double up slipper hub & use either the aluminum pads or use a old stye #4964 T maxx brake disk.
    http://www.hot-racing.com/index.cgi?...=TRX15GP;c=431
    http://www3.towerhobbies.com/cgi-bin...&I=LXSP66&P=ML
    Look out for the tree/crunch!
    LiPo? Naw NITRO!!
    448
    I like it, but would you show a complete layout in the order of how the parts would assemble. Like from the (referencing your top photo) end nut (on the right) to the set pin (all the way on the left).
    McKinney, Texas
    811
    These would've also been a good pads to use. I have them on my Pede 4x4 and they work really good.
    http://www.hot-racing.com/index.cgi?...TRX15HSL;c=480
    Jun 2009
    Cocoa Florida
    3,808
    Quote Originally Posted by ReglarDude View Post
    The Hot Racing slipper plates just replace the stock pieces.
    It assembles just like stock, the only difference is the T maxx brake pad in place of the 3 slipper pads.
    The holes in the brake pad need opened slightly to sit on the alignment pegs, which can be done with a drill bit or file.
    LiPo? Naw NITRO!!
    448
    Yes, but it looks as though each pad hole of yours' has an alignment peg in it. My stock plate holds 3 small pads, and only has 2 pegs per pad which (of course) is 6. Yours' looks to have a total of 12 holes with a peg in each hole.
    Jun 2009
    Cocoa Florida
    3,808
    That's because your's is the stock slipper & the one in the pic is the Hot Racing "Double Up" slipper, it will hold 6 of the stock type pads.
    It goes together just like the stock slipper does.
    Here's what it looks like with 6 of the aluminum TRX slipper pads on it.
    LiPo? Naw NITRO!!
    448
    I'm with you now, thanks.
    448
    Here you go RC. The first part is from Robinson Racing, and the last part is from Hot Racing.
    448
    Here you go Dann117elite.
    368
    Isn't the Robinson racing one only for the erevo
    The smartest person, asks the most questions...
    448
    The one for the Revo works in our Emax's.
    368
    Is it better then say the hr one?
    368
    No one? I'm just wondering which is the strongest/best set-up
    Jun 2009
    Cocoa Florida
    3,808
    There's a bunch of BL revo guys running 6S with the HR/brake pad setup, and there's the Robinson racing(#7960&#7965), your stuck using a steel spur.
    The HR/brake pad setup is what I plan to use on my BB Nitro truck.
    LiPo? Naw NITRO!!
    448
    What does BL for? Also, when I said the Revo one works with our Emax, I was referring to the Hot Racing one...just to let you know.
    Jun 2009
    Cocoa Florida
    3,808
    BL=Brush Less.
    Yes the Hot Racing slipper fits multiple vehicles, Revo, T-Maxx , Summit, Long Chassis e-maxx, 4x4 Slash.
    As long as your truck has the Revo spec slipper, or the slipper conversion kit installed in it, the HR slipper will work.
    LiPo? Naw NITRO!!
    448
    What torque setting would you use if you have the HotRacing set-up with the 6 aluminum pads, and what torque setting would you use if you have the HotRacing set-up with the Tmaxx brake pad? The normal Traxxas stock set-up, torque setting is; back 1/4 to 3/4 CCW turn from the full tight position.
    368
    I would do the same 1/4 turn and only adjust if required
    448
    Dann117, did you do the 6 aluminum pad mod or the Traxxas brake pad mod & what was your final setting?
