    19
    No power to rear wheels
    I just recently bought new front and rear differential for my Revo. And now it seems to have no power to the rear tires. If I pick the rear end up off the ground and give it gas it spins the tires, but as soon as there is any load on it, it will not turn the wheels. I have checked the drive shafts, made sure the tires are properly installed, the slipper clutch is tight. I have even tried putting my old differential back in and it does the same thing. I am starting to think that it might be my center differential going bad. Is there any way to test it to see.
    Gurley, Alabama
    766
    Open it up.
    milwaukee wisconsin
    169
    i would be willing to bet that one of the gears arent tight enough together because i had that same problem except with my clutch bell
    May 2006
    Dayton Nv.
    3,181
    Pick the truck and give it gas to see if both front and rear wheels are turning the same direction.
    Gurley, Alabama
    766
    Quote Originally Posted by fallonguy View Post
    That would be one confused truck.
    May 2006
    Dayton Nv.
    3,181
    Quote Originally Posted by Mark Ball View Post
    The differentials can be put in upside down (they are marked as to which way is up) so if you put one in right and the other in upside the wheels will turn in opposite direction.
    131
    check if the pin for the axles are in that what happen to me
