Results 1 to 23 of 23
    Nov 2011
    404
    Rally body ventilation
    The rally isn't known for its superb ventilation so I would like to somehow give some more "cool" to the motor/esc. Anyone have any ideas?
    Riverton Utah
    4,361
    Try cutting a hole in the windshield where the motor is behind it.
    Nov 2011
    404
    Just found this pic on an eBay listing for the roll cage. Do you just do that with a hobby knife?? Or is there a special technique or tool to do it with? Sorry if I may sound stupid if its obvious.
    Jul 2009
    Ontario, Canada
    11,145
    Now that ^^ Looks cool. Too bad the cage would be so heavy. Maybe someone could make a full cage out of plastic. That would be sweet. Id add one for sure.
    Pede, Summit,
    ERBE, Rally,
    Motley Crew, 1SQ
    Nov 2011
    404
    I'm gonna cut a hole in the windshield like in that pic tonight for sure. My rally is running a little hot
    Nov 2011
    404
    I didn't feel too comfortable cutting out the windshield so instead I cut out the grill which will still deliver some cooling to the electronics and motor. Plus I like the way this looks too.
    RC Turnbuckle Jr. rjm2519's Avatar
    Feb 2008
    Fl
    3,062
    I would look for some kind of mesh and frame to replace the windshield or windows to keep the structural integrity of the body but also ventilate and keep dirt out. Or cut out small vents that blend with the body and decals.
    Donít handicap children by making life easy
    South of St Louis
    5,986
    Is there any good way to measure the effectiveness of this? I'm know it works but I haven't found a good way to measure it other than the motor temps are lower.
    Traxxas Employee Texas Wheelman's Avatar
    Plano, TX
    563
    Quote Originally Posted by Nitroelectric View Post
    The only stupid question is the one not asked. Sometimes we might refer you to your manual, but it's best that you tap into the wealth of knowledge from the folks on here.
    I use an x-acto knife, smaller blade, and a NEW one. You have to go slow and be very steady, and just score the plastic, put a groove in it where you want to cut out. My hands are not steady, so I end up with wavy lines. Not that big of a deal, since we're looking more for function than fashion at this point. Then go back along those grooves with lighter pressure, to thin the plastic more. Usually you can just push the piece out at that point, but if it won't go easy, cut the groove again. If you try to push it out when it won't go, you'll end up with a big tear across some other part of the car that you didn't want.
    You can also cut a few grooves all the way through with a knife and then use scissors.
    It's never too late to have a happy childhood.
    Nov 2011
    404
    I already decided not to do the windshield and used an x-acto knife. I know how to cut out parts of the body I just never did a windshield before. Since its a big part of the body I thought there was a special way to do it.
    Plano, TX
    563
    Oh ok. Let us know how the ventilation turns out.
    Covina, So Cal
    638
    I was having the same problem. I cut the grille out, and used a body reamer to put holes in the front and rear windows. It helped quite a bit lowering temps.
    A quick note on the pic above with the roll cage, that's a friend of mine who posted that pic to show the cage he builds for the Rally. He does NOT recommend completely cutting the windows out, as you will take away all of the body continuity and cause the roof to collapse. Unless.... you have a cage of course!
    AB
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    I'll try anything once, maybe twice!
    Nov 2011
    404
    That's a super neat idea. I like it! Although I can't do any of this because my rally is temporarily dead for another week or so. (Bad crash) Also love your rally, it looks really sweet. And also tell your friend that he should be expecting an order for one of those roll cages very soon!
    Australia
    3,259
    Very creative idea mate...nice!
    Rock n Rolla !
    Covina, So Cal
    638
    Thanks! Check this post...http://traxxas.com/forums/showthread...=1#post5513595
    Quote Originally Posted by MITCH316 View Post
    Thanks Mate! It works very well.
    AB
    Glens Falls New York USA
    653
    Aburg can you link that tire and wheel set? Someone should start a wheel thread of which ones work best. Iv tried the supra sales on my slash and had the wheel popping off issue that been discussed in another thread. The supras don't allow you to screw the wheel far enough on.
    Covina, So Cal
    638
    Quote Originally Posted by CoreyM View Post
    Those are Pro Line Road Rage Street 1:8 Buggy tires mounted on Pro Line Split Six V2 Black wheels. The tire part # is 9012-00, & the wheels are 2724-03.
    BTW, I have several sets of Suprasales wheel/tire combos, and have had no problems with them. I even wore a set of road tires bald, without them ever coming loose. What hubs are you using? I'm using XO-1 17mm hubs.
    AB
    653
    Quote Originally Posted by aburg2 View Post
    AB
    This was on my slash not my rally. On my slash I'm using the tekno 17mm adapters. I have traxxas 17mm adapters to put on the rally. I have not put them on it yet though. As I'm still collecting my parts before I put it all together.
    Covina, So Cal
    638
    I have the XO-1 17MM hubs on my Slash too. I'm also running Suprasales, and tearing it up with them!!![IMG][/IMG]
    AB
    653
    Is there a difference with the xo-1 17mm and the standard traxxas 17mm adapters?
    Australia
    3,259
    Yes, they come with an offset and hub retainer...post #88 shows you a pic of the X0-1 adapter
    http://traxxas.com/forums/showthread...=1#post5444236
    Rock n Rolla !
    Australia
    3,259
    AB
    I may look at doing this to my PF8-GT body if I can't get my motor temps under control.
    Rock n Rolla !
    653
    Love the avatar!
