Results 1 to 12 of 12
    Sep 2012
    Toronto
    94
    Summit Steering Issue!
    Hi guys,
    Please see the next video and let me know if you have any idea about what's wrong with my steering system!
    Video description:
    "As you can see in the video, by steering left everything works fine and when release the wheels are comming 100% back .. but when I'm steering right and release the wheels are not coming all the way back! I've tried to open and clean the steering system but without success! what can I do?"
    This happened after I replaced the front wheels bearings.
    Thanks in advance,
    Like & Share: Facebook /ScutuPhotography
    Apr 2013
    Ontario, Canada
    778
    Seems weird to be an issue from changing wheel bearings... Looks like a servo issue. Either alignment, linkage of bad servo electronics. Not sure. But I would try removing the servo horns and checking the rotation degree of the servos while not connected to the horns. Then also checking how easily the steering linkage can be turned by hand.
    Sep 2012
    Toronto
    94
    hmm .. it looks like I'm not the only one having this issue:
    1,161
    by any chance did you tighten the pillow balls up? I had the same issue on a maxx after adjusting pillow palls had one side a little tight. Showed the exact same symptom you have
    Half moon building out back
    730
    Like Crock said check your pillow balls and make sure they are not to tight, next thing would be a broken tooth on a gear in one of the steering servos.
    Endeavoring to persevere !
    Sep 2012
    Toronto
    94
    Thanks guys for your thoughts,
    The pillow balls can't be to tight, otherwise the suspension would be very slow or stuck and it seems to be fine!
    I'll open this weekend the servos and check the gear teeth!
    1,161
    The suspension worked fine in my max. It was just one screw to tight. Don't rule it out untill u try
    Arkansas
    522
    Yep those dang pillow balls can cause that bruise on your forehead to get bigger and bigger; I don’t why but I always seem to overlook them.
    I’m sure everyone has their own method but I tighten them until they’re snug and then back them off ¼ of a turn.
    I have now started to just check them first. ESC smoking......check the pillow balls. Shift Servo won't engage......check the pillow balls. LOL
    SUMMIT, SUMVO, ERBE, EMAXX & REVO 3.3
    Sep 2012
    Toronto
    94
    boom .. I fix them .. you're right .. the pillow balls were too tight!! .. now I'm afraid to don't lose them :P ..
    This is the beast!!
    Thanks ppl
    1,161
    They usually don't back out much. I have tightened mine once in 6 months. I also fill mine full of white grease. The dust seal has a x in it so u can push grease or oil in
    15,442
    I'd use powdered graphite along with teflon tape on the pillow ball caps.
    Alt-248 on the number pad = °
    Sep 2012
    Toronto
    94
    I'll keep an eye on the pillow balls from time to time .. but they should be fine!
    I'd put diff oil on them.. it will collect dust but this will keep the water away
