Results 1 to 13 of 13
Thread: Revo
    May 2013
    21
    Revo
    My revo keeps over heating how do i fix that
    Mar 2013
    Australia, vic
    137
    Richen your hsn
    May 2013
    21
    It's perfectly tooned thou
    Tanker 822
    9,675
    Then it shouldn't be overheating.
    May 2013
    21
    Could it be because my air filter has stuff on it I clean it after every run
    Riverton Utah
    4,351
    Richen the lsn a little. If the low speed is lean, it can heat the engine up even if the hsn is rich.
    Riverton Utah
    4,351
    I'm guessing that mean you don't clean it after every 4 or 5 runs? That could be a slight part of the problem. The air filter can even be dirty after driving it on pavement. It doesn't even have to look dirty for it to be full of microscopic dust and dirt.
    Gurley, Alabama
    766
    If the air filter is clogged it would run rich due to the lack of air, it would smother out. As the others have said, it's too lean somewhere. Or you could have bad fuel that doesn't have enough oil in it.
    May 2013
    21
    Another thing I have notice is my truck doesn't have a lot of smoke coming from the exhaust but my dads dose
    Mar 2013
    Australia, vic
    137
    Get your dad to tune it
    May 2013
    21
    Ozrevoguy I have he said that it was perfectly tooned
    Jul 2012
    edmonton alberta canada
    72
    Totally not trying to sound like an edit but maybe dad doesn't want you driving in second gear?
    Gurley, Alabama
    766
    A lot of guys have overheating problems because of their idle gap. You can make it idle at a decent rpm with the idle gap off by having the lsn off. Try starting off with the gap around 0.7mm and then start retuning from there. You'll probably need to richen the lsn right off the bat. Then just follow the basic 6 step process, hsn, lsn ,hsn ,idle,hsn ,idle. Now that I have learned to tune these little buggers, I just make very small adjustments to one or two needles at a time keeping up with the temp changes outside and watching the engine temps.
