Results 1 to 15 of 15
Thread: Tire Glueing
    Apr 2013
    126
    Tire Glueing
    I got some trenchers yesterday and I need some tips on how to glue them onto my wheels.
    SLASH 2X4 VXL
    VINTAGE BIG BEAR
    Michigan
    5,246
    I hate gluing tires,only run bead locks unless I have no choice.
    You might want to check out youtube they have a lot of videos on tire gluing.
    I guess it's not that bad,I just cut my teeth on bead locks and with only a few exceptions never looked back.
    Mount and go,no waiting.
    Apr 2013
    126
    I'm sorry, but what are bead locks?
    SLASH 2X4 VXL
    VINTAGE BIG BEAR
    Michigan
    5,246
    Their rims that require no glue.
    You just mount your tires,snug the screws and run your truck.
    They are a bit on the heavy side,and cost more.(about $22 a pair)but after you wear out your tires or just want a change,you take out six screws put on your new tires replace screws and go.
    This is what they look like.
    [IMG][/IMG]
    These bead locks only work on 2.2-3" tires,but I'm sure you can get 2.2's on both sides,s.
    My crawler used them,but they would never take the speed of a slash.
    N. Idaho... Da Sticks!
    3,378
    Check out the tire glueing How-To from Jang at Ultimate RC on YouTube. He goes through it step by step.
    Apr 2013
    126
    Jang is a god. Jang knows all.
    SLASH 2X4 VXL
    VINTAGE BIG BEAR
    Michigan
    5,246
    Quote Originally Posted by gingersquirrel98 View Post
    He has a lot of very good videos out for just about everything rc.
    I glued this set up,because I found jc concepts tires don't play well with pro line bead locks.
    Good luck.
    [IMG][/IMG]
    Brooklyn Park, MN
    1,076
    Make sure you wash the wheels and tires with soap and water before mounting. You also should scuff up the bead for a better bond.
    MM|2200kv 2WD LCG Slash - MM2|2650kv LCG Slash 4x4
    Apr 2013
    126
    What should I use to wash them and how should I scuff the beads up...
    Sorry about all the questions... but I want these things to look good. I have the jconcepts rulux wheels and they look sick with the trenchers.
    and also how can I prevent them from ballooning?
    SLASH 2X4 VXL
    VINTAGE BIG BEAR
    Michigan
    5,246
    Again a good youtube way to go.
    Most people belt them.
    they turn the tire inside out and put duct tap around them.
    Then turn them back the right way and mount them up.
    Then the tap will hold the tire from ballooning out.
    Brooklyn Park, MN
    1,076
    Take the foams out and use some regular old dish soap and hot water on them to get the oils off. The glue sticks much better when it is bare.
    I use a dremel on my rims, but a wire brush will do just the same to scuff them some.
    I use gorilla tape on my tires and it works really well. No ballooning of the 2.8 trenchers(not sc) at 50+mph
    Apr 2013
    115
    is it bad if the tire balloons
    Brooklyn Park, MN
    1,076
    Not really a bad thing except at high speed(40-50?). It makes it a lot less controllable and more prone to a tire ripping or something.
    It really makes a difference with big ol' 2.8 tires or any aftermarket tire going fast. Not so much with stock slash tires, they don't seem to care, they are so hard.
    Apr 2013
    126
    Ive seen some videos on tire ballooning, dang, those things can get huge.
    SLASH 2X4 VXL
    VINTAGE BIG BEAR
    Brooklyn Park, MN
    1,076
    Taping is the best thing ever for high speed handling but don't get them wet, and prep them well(wash with soap)... or the tape might rip from the tire leaving you with a very poor handling truck. which you'll need to de-bond the glue and its just a big mess, do it right the first time..
