Results 1 to 13 of 13
Thread: Revo
    May 2013
    21
    Revo
    My rod ends keep coming off of my toe rods is there anything I can get to prevent this
    Jul 2006
    2,153
    Yes, replace the ends.
    Believe 1/2 of what you see,and 0 of what you hear
    May 2013
    21
    I did but is there an after market part that I can get to prevent this
    Jul 2006
    2,153
    No. They should not be coming unscrewed.
    The rod ends do not have threads in them, and screwing the rod into is actually forming the threads. This is not an uncommon fastener type. The rod ends should only be looked at as a one time deal. You screw it on once then leave it. It is not meant to be unscrewed and screwed back on. At that point, the internal threads are loosened. If the rod end pops off the rod, don't bother screwing it back on. Replace it.
    Gurley, Alabama
    750
    RPM makes long rod ends in black, blue and white. They stay on A lot better than the stock ones, probably because there made by RPM. Everything is stronger in RPM land.
    May 2013
    21
    How they come off is I sometimes do backflips and they came off that way that's how they came off
    Jul 2006
    2,153
    I hear what your saying. But, there is no way to glue them on or anything. The harder you bash, the more that is gonna go wrong. I would just stock up on ends, or try the RPMs that were suggested.
    May 2013
    21
    Thank you so much for your help!
    Mar 2009
    1,830
    is this the rear rod ends for the push rods, the ones that connect to rocker arms?
    you know.. i never had a sig.. but i do now...
    Oct 2005
    South Florida
    18,371
    Are you saying the rod ends are popping of the silver pivotball? If so the rod end is worn out.... Replace it and your good to go...
    This often happens over time, taking jumps, landing heavy on 1 wheel here and there....
    Founder of H.U.A.
    Hop Ups Anonymous
    May 2013
    21
    It is the front
    Jul 2006
    2,153
    Nitronaught is asking a good question. Is it that the rod ends are popping off the tie rod shaft, or that the rod ends are popping off of the pivot balls?
    Aug 2012
    37
    Well, these things happen sometimes when you bash. But if its happening on a regular basis, try the rod ends - #5348. These are made by Traxxas for rear toe links, but you can use them all around, no issues. They are pretty heavy duty and I've seen many people using them on their Rock Crawlers with good results. Though nothing lasts forever, but these rod ends would definitely help in my opinion. They are much better than the stock ones.
    And as OOmp says, "If the rod end pops off the rod, don't bother screwing it back on. Replace it. "
