Results 1 to 18 of 18
    Apr 2013
    67
    steel diff gear?
    im looking to rebuild my transmission, and want to put a solid steel diff gear in it, just dont know if they make one for it, i found an axial diff gear that looks right but dont wanna get it untill im sure it will work, any help here?
    FREEDOM IS NOT FREE, EVERYONE PAYS THE PRICE
    Marshal Dadx2mj's Avatar
    Aug 2007
    So Cal
    21,251
    You man an all metal diff housing? FLM makes one I believe there are a few others on the market as well.
    http://www.fastlanemachine.net/prodd...LM20010&cat=14
    BlindMan Racing
    Rusty - MERV - Pede 4x4-Alias
    SPC Lipo Power
    phoenix
    1,118
    i was thinkin about pickin something like this up. i hear good things. so im thinking one of these diffs with some thicker than stock(what ever stock is) diff fluid so i get less slip and more equal spinning of the drive tires.
    Apr 2013
    67
    im saving that site lol but yah thats what im looking for, but its rather exspensive
    Aug 2007
    So Cal
    21,251
    Quote Originally Posted by redlightrandy View Post
    Stock diff uses grease not diff fluid and it is not a sealed unit so if you try to use diff fluid it leaks out rather fast. Even the grease gets forced out of the stock diff.
    BlindMan Racing
    SPC Lipo Power
    Biggest Little City In The World
    723
    Look into the Hot Racing sealed diff. It comes with lots of great reviews. I use one and love it. Unlike the stock diff the HR diff is sealed so you can add diff fluid to get the spool feel and still be a open rear end.
    http://www.ebay.com/itm/Hot-Racing-T...item5d3eb0696a
    " You just got passed by a Traxxas"
    Apr 2013
    67
    that one is more in my price range, might have to get it, thanks for your input guys
    phoenix
    1,118
    do the screws of the hr diff need any thread lock?
    St. Louis
    28
    Some people sat that hr ones seep out around the screws, also i WOULD put thread lock on them, because it is metal on metal and that might help the seepage.
    723
    not thread lock, use teflon tape on the screws, only fill the diff half full and use grease or green slime to prelube the gaskets and xrings on the out put shafts. Check out the Hot Racing sealed differential review for more info and tips and tricks.
    Apr 2013
    67
    what weight of diff oil/grease would you advise for a sealed diff system?
    13,134
    Start around 50,000 wt. You can then decide to go up or down in wt if you need a stiffer or looser diff. wts avail go from 1000wt all the way up to 500000 wt. You have a ton of options there. In my sealed diff(sealed stocker) I wound up liking 100,000 wt for bashing, but kept leaking out. The hr diff has been working for guys on here much better than the modified stock diff.
    723
    I like 50k in my HR diff. I race on a very high traction hard pack clay surface. I tried 100k weight and i got to much push in the corners, the diff acted to much like a spool. So i went back to 50k and thats what i been using. I get good straight launches very little if any push around really tight corners. The amount of grip on the surface you mainly race/bash on is gonna dictate how thick oil you want to use. The thicker the oil the more it will act like a spool (locked diff).
    190
    I run the traxxas pro ball diff. I would deffinately recommend it.
    Sep 2008
    West Palm Beach Fl
    4,073
    Quote Originally Posted by zreuille98 View Post
    I love ball diffs. But unless you know how to exactly build a ball diff(alot more involved then following the instruction with the traxxas one) or running mild power the traxxas one strips easily.
    Simply the best. The beautiful Traxxas SRT and TCP
    4,356
    Apr 2013
    67
    holly cow MIP is so exspensive, i have their drive shafts, payed $45 for them
    Sep 2008
    West Palm Beach Fl
    4,073
    the Mip isn't a upgrade over the traxxas ball diff. Still strips easily. The gear itself needs to be made of hardened aluminum. Like the Robinson rc10gt diff gear is. Year it for years in my t4 under any brushless setup and not even a scratch in the gear.
