Thread: Confused
    ID
    52
    Question Confused
    I was adjusting the camber and toe on my ERBE the other day and took it out and the shocks were not working at all they would work fine at first but then it would bottom out and never come back up. whats happening?
    Rustler Vxl, Merv, ERBE, Jato 3.3, and others
    Australia
    3,257
    Check to see if your pivot balls caps aren't binding with the pivot balls from been over tightened. Also check that the hollow balls in the rod ends aren't binding either, I usually give mine a squirt with WD40 and then blow excess off with compressed air.
    Rock n Rolla !
    ID
    52
    Well i checked it all and sprayed some wd 40 on it and its still doing it.
    316
    shocks may just need some more oil --- maybe try a little thicker oil in there too
    make sure nothing if hitting the shock the would stop it from coming all the way up
    Australia
    3,257
    What WT shock oil and springs are you running? I'm running 60 WT oil with Black springs Front and Pink rear.
    Rock n Rolla !
