Results 1 to 19 of 19
    3
    Question help me beat the rc10"s
    im running a slash 2wd vxl with the velineon brushless system. im also running 2.2 rims and tires(slicks). on a paved oval (short). also a 2cell 50c lipo pack and i cant keep the motor cool. what gearing should i run? currently pinion is 23t and spur is 76t. thanx twisted
    Michigan
    5,071
    It wont help cool the motor,but 2.2/3.0 rims might help it handle better.
    If you don't need that much top speed,go with a 86(stock vxl) spur,and the 23 pinion.
    Yesterday I dropped to 20/86 on a tight sct,and kept the temps in the 150's(degrees).
    If you have long straight's,you might want to look it a castle or any brand 4 pole brush less.
    They tend to run cooler.
    But the velineon is a nice set up as well. I have castles but we have been running the velineons to get my grandson into a faster truck.
    What are you running for temps? And what time lengths are the races?
    13,098
    Check out chuckworks rc. They have a mid motor lcg chassis that will really help corner speed on a tight high traction oval. It got me the track lap record for an sct.
    How hot is the motor running? What actual temps are you getting at the end of the race?
    3
    bout 200 the hottest. when i was testing bout 15 min of hard running
    ive done alot to this truck protrac suspension kit, strc lcg kit, aluminum shocks. 2.2 tires to get it to handle right and not roll over now its running hot any ideas?
    13,098
    That 1 time(or more?) that you overheated it caused some damage. Now it will overheat even faster. Not sure why it got so hot in the first place on 2s though??? If you got it to 200, you will prob need a new motor. Never let them top 180...
    Jan 2008
    South Jersey
    8,231
    Quote Originally Posted by twisted71d View Post
    23/76 is way too high for a Slash on 2S. The 76-tooth spur was intended for the Bandit, which has a much smaller wheel diameter. Try an 83 or 86 spur with the same pinion. It will probably accelerate faster and have more top speed too with lower temps because your current gearing is way too high.
    Biggest Little City In The World
    723
    +1 on the 86t spur.
    I also run a STRC LCG Slash 2wd i dont race circle track but i do race short course. When i ran the VXL set and on my current Hobbywing set up i run the 86t spur and 20t spur 2s 5000mah 35c-70c lipo and can keep up with the factory trucks no problem. On the VXL it was rare to see temps at 125 and on my Hobbywing even after a 8 min main consistent 115 degrees. You can also put some cooling fins(heat sink) on the motor and if you need more add a fan. Also a aluminum motor mounting plate will help with temps.
    Honestly though it sounds like a simple gearing change is gonna fix most of your problems. Good Luck
    " You just got passed by a Traxxas"
    3
    thanx guys im gunna play with gearing and go from there
    Central KS
    1,071
    Good luck. Gear down, but you may really already have damaged the motor. If you decide to buy a new motor you could get a Castle SV3 ESC/motor combo with 4600kv 4-pole motor and have more torque and more top end than you currently have.
    Sep 2008
    West Palm Beach Fl
    4,057
    What systems are the others running? Believe or not a less powerful system can actually make you faster bc of the control. If these sc10 are running Tekins and LRPs just to name a few those timing boost sensored will blow the doors off the vxl. Also when you remove the motor just spin the drivetrain to make sure there isnt any binding.
    Simply the best. The beautiful Traxxas SRT and TCP
    woodstock .on.canada
    2,194
    if you want to keep the motor i would sugest getting a replacement rotor for it
    heat weakens the magnets ....and by replaceing the rotor you will be replaceing the magnets
    Nashville, TN
    1,784
    If your truck is stock, then lowering the COG will help a lot too. The STRC kit is good, as is the pro-line LCG chassis.
    Central KS
    1,071
    Wouldn't replacing the rotor only be replacing _half_ the magnets? Granted its the only rebuild option on brushless but I'm just checking my understanding.
    Jan 2008
    South Jersey
    8,231
    Quote Originally Posted by OlorinTharkun View Post
    The magnets are on the rotor only. The can holds all the copper windings, or stator.
    13,098
    Never thought to ask before this thread, do the coils get damaged as easy as the rotor when overheating???
    Central KS
    1,071
    Ok, thanks Harry. I was confused because I took apart a DeWalt cordless circular saw and it looked like it had magnets on both the rotor and stator.
    Jan 2008
    South Jersey
    8,231
    That's a brushed motor, but basically just the opposite of how your brushless magnets and windings are. Those aren't magnets on that Dewalt armature. Those two big ones inside the yellow housing are the only magnets I see.
    Central KS
    1,071
    Doh! You're absolutely right that its a brushed motor. But I thought it looks like magnets surrounding the coiled wire also.
    Feb 2008
    Fl
    3,062
    Those are the electro magnets, but the brushless use a more sophisticated coil that doesn't have defined electro-magnets like brushed does.
    To the OP I would stick with a 2 pole setup and maybe go sensored if you need a new motor. IMO 4 pole will be a lot more torque than you need in a 2wd, also try using the 83t spur and a 20-23t spur first, before jumping to the 86t, remember every little bit of weight especially on the drive-line affects performance if only a little. You may even want to try an aluminum pinion. Good luck and keep us posted!
    Sent from my Torch!
