Results 1 to 11 of 11
    Apr 2013
    10
    Is there a difference between revo and summit RPM A arms.
    I want to use revo CVD's, can i use my summit rpm a arms and the revo P2 rockers?
    Burley idaho
    160
    Yep. The summit and revo ones are the same.
    Alma, MI
    11,950
    No, they are not.
    In the front, the arms are the same... in the rear, they are different. The Summit's rear arms are swept back 10mm.
    RPM does not make Summit arms... they make Revo arms that fit on the Summit and since the Revo comes stock with P2 rockers the combination works well together.
    Rotterdam, Netherlands
    7,027
    RPM arms at the front reduce the amount of suspension travel compared to stock ones.
    Nobody is born with experience.
    Burley idaho
    160
    Sorry i meant the rpm one for the revo is the one you use for the summit.
    May 2013
    WA
    24
    No, they are not.
    Yep, the RPMs are more forward in the rear. They fit the Summit ok but the top arm rubs the drive shaft a little. I just switched to the Traxxas CVD's so no more rubbing. Its my sons truck so I try to put as many parts on it that I know will be easy for him to break if they were stock.
    Apr 2013
    Pacific Mo.
    120
    Will the rpm arms work on the summit with the long travel rockers?
    Alma, MI
    11,950
    Yes, they will.
    Apr 2013
    Pacific Mo.
    120
    I'm assuming they work with the summit push rods too?
    SE Texas
    1,179
    Yes they will.
    The only suspension differences between the revo and summit are the rear arms,rockers,and springs.
    "Dude,I almost had you"
    R.I.P Paul Walker
    Apr 2013
    Pacific Mo.
    120
    Ok, thank you
