Thread: shock springs
    Apr 2013
    36
    shock springs
    When I push down on the back of the truck it doesn't rise back up very fast. It always seems like its sagging with the body on. it seems like the back tires hit the body almost. So I would assume I need stiffer shock springs. I have the factory ones on which are single yellow on back and single white on front. Which ones would I need to stiffen up the back?
    Dec 2008
    Gettin' Lucky In KY
    3,880
    Orange and Green stripe are the next two stiffer springs than stock. There is a chart in the manual with spring rates and color codes. The white ones in the front are actually stiffer than the Yellow. You might just try swapping them and see what happens before you buy anything.
    Apr 2013
    36
    Quote Originally Posted by CarGuy7a View Post
    Ya I can't find my manual otherwise I would of looked in that because I knew it was in there.
    Dec 2008
    Gettin' Lucky In KY
    3,880
    Quote Originally Posted by kuca_2004 View Post
    That's fine. It happens. There is one you can download from this site. Go to the Products tab, then nitro, Slayer, and downloads. It has all the exploded views and manuals. Pretty useful.
    Putting the water on the hot stuff
    9,698
