Results 1 to 7 of 7
    57
    Really hot motor
    My motor is very hot after a run. After almost 5 seconds of touching it I can't because its too hot. I have 18/58 gearing. Why's my motor running so hot?
    The Netherlands
    851
    Can be too big tires, hot weather or tough driving conditions like loose sand. Tell us some more about your siuation. Also try to get a temp gun so you can actually measure temps.
    72
    Purchase a temp gun from home depot for $20. Run your car again for the same amount of time and check temp.
    Reason why, Is because for awhile I thought the engine was burning and getting too hot. But then I bought a temp gun only to find temps were only in the 135 degree range. Which is very safe range.
    San Diego, California
    507
    Get an actual temperature reading from it, then report back. I thought mine was way too hot, but it was actually at 140, which is perfectly acceptable.
    57
    I just ran it for what seemed to be about the same amount of time. I got a reading of 140 degrees.
    3,259
    5s to touch is not too bad...it probably puts you up around the to 66C mark. Get a temp gun or a racetemp gauge which it what I have...post #99
    http://traxxas.com/forums/showthread...=1#post5300120
    keep an eye on temps and maybe try running 20/54 if 6s or 21/54 for 4s.
    Rock n Rolla !
    kansas
    7,864
    Quote Originally Posted by JD 3592 View Post
    looks good... 140 *F is perfect...
    http://traxxas.com/forums/showthread...=1#post5497869
