Thread: Jato steering
    Feb 2009
    New York City, Virginia Beach
    150
    Jato steering
    Just installed new servos, but my Jato is pulling to the right hard.
    Everything else is the same is the center the arrow pointing up?
    Any suggestions?
    Thanks in advance..
    Newbie
    Gurley, Alabama
    766
    You have to center everything with the front end still off. First turn on the transmitter, then the car and the servo will automatically center. Hold the wheels straight while sliding the servo horn onto the servo. Make sure the wheels are pointed where you want them while holding the front end in place, before bolting it back on. If not, adjust the servo horn and check again. Oh I forgot, make sure your steering trim on the transmitter is centered before starting the process. The servo horn won't necessarily be pointing the exact same way as the old servo, but should be fairly close.
    Feb 2009
    150
    Thanks mark.. I believe I have it now.. Had it out .. For a few spins.. It's back to its prior form..
    Newbie
